LG4 rebiuld
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
LG4 rebiuld
Hi!
What pistons do I need to get 9.5:1 compression ?
I want these pistons +5сс
I will get 9.5:1 compression?
Car: Camaro 1988
Re: LG4 rebiuld
I buy this engine. Cast #14010203
I want rebuild and new carb,cam,piston,intake,headers.
Car: Camaro 1988
Re: LG4 rebiuld
My heads #14022801 (1.84/1.5 valve)
I want instal:
-intake edelbrock 7501
-cam CS XE262H-10 http://www.summitracing.com/parts/cc...make/chevrolet
-carb Holley duble pumper 600cmf
Question.
What do I need pistons and head gasket for 9.5:1 compression.
Can I put a 1.6 rocker?
I want instal:
Question.
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Re: LG4 rebiuld
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: LG4 rebiuld
Here's a compression calculator--> http://www.csgnetwork.com/compcalc.html
There are a lot assumptions you will have to make unless you actually measure the chamber volume. I have yet to see a combustion chamber measure out identical to what they manufactures spec is suppose to be. Usually they are within one to two cc's though.
Car: Camaro 1988
Re: LG4 rebiuld
I used this calc http://www.summitracing.com/popup/ca...ion-calculator
I do not know what to do compressions correct 8,6/9,3/9,5/10,0
In my country, no one build SBC!
I hope for your help!
Re: LG4 rebiuld
Those flattop pistons with stock heads will get you right around 9.5:1 (9,5:1 is how you would write it!) compression. You're fine.
I wouldn't do 1.6:1 (1,6:1) rockers. It's not just the lift, it's also the fact it can cause the pushrods to bind against their alignment slots in the heads.
Get the right springs to work with that cam. Not that you will bind up the stock ones, but they will not have the pressure necessary to control the valvetrain with a more aggressive aftermarket cam in the higher RPMs. Comp 981 springs are what you want. They are drop-in replacements for stock. Reuse your stock valves, locks and retainers (even the stock exhaust-side rotator-retainers).
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: LG4 rebiuld
Just for fun, English to Ukrainian then back to English:
Those aircraft carrier pistons with stock heads help you right at 9.5:1 (9,5:1, as you would write it!) Compression. You're right.
I would not 1,6:1 (1,6:1) rockers. It's not just in the elevator, it is also a fact, it can lead to pushers to link against its alignment slots in the heads.
Get the right springs work with this camera. Not that you'll associate stock them, but they will not have the pressure required to control valve with a more aggressive aftermarket camera at higher revs. Comp 981 springs that you want. They drop in replacements in stock. Reuse your stock valve locks and retainers (even the stock exhaust side rotator-brackets).
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: LG4 rebiuld
any one know a ball park pushrod length for 305/350 pre roller era? i know i know get a length checker.... but seriously... any help would be awesome
85ws6TA
Jun 27, 2001 12:25 PM
Conv389drv
Aftermarket Product Review
Dec 12, 2000 12:46 AM
