liquid in air filter housing
Old Jan 30, 2013 | 10:14 PM
the blue one's Avatar
Car: 1988 base
Engine: 305 tbi
i believe i have a small amount of oil laying around my air filter. inside the housing theres a small puddle around the edges of what i think is oil. why is this happening, is it going to cause damage, and how can i fix it? i will post a picture shortly
Old Jan 30, 2013 | 10:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: liquid in air filter housing
engine blowby
Old Jan 31, 2013 | 02:34 PM
Car: 1988 base
Engine: 305 tbi
it's the breather, i think it's just splashing oil up in there
Old Apr 7, 2013 | 01:23 PM
Car: 1988 base
Engine: 305 tbi
well. my air cleaner is still getting oil in there somehow. i dont know why it would be coming up the oil breather like that. im also not sure if it has somthing to do with my car smoking every time i start it up.
Old Apr 7, 2013 | 01:27 PM
Engine: Lb9
Transmission: M20
The minimum sounds like you need to do valve guide seals and a pcv valve.
Old Apr 7, 2013 | 01:42 PM
ex-x-fire's Avatar
Does the car have a lot of miles on it? Most likely has a bad ring seal.
Old Apr 7, 2013 | 02:04 PM
Car: 1988 base
Engine: 305 tbi
it has around 107xxx, had about 5 years of sitting in sombodies driveway being started twice a month
Old Apr 7, 2013 | 02:14 PM
ex-x-fire's Avatar
Well first check the pcv hose, those tbi are known for carbon plugging the pcv & vacuum ports, if clogged, remove the whole tbi unit & use a drill to clean them out. Get a new base gasket.
Make sure the pcv valve rattles.
Have a leak down test done on the engine.
Really, if the vacuum hoses & pcv check out ok, driving the car around won't be too much of a problem. Just check you oil level every other fill up. Its probably down on power & might fail emissions test though.
Old Apr 7, 2013 | 03:04 PM
Joe Tag's Avatar
LOL don't say "drill" MAYBE a drill bit twisted by hand. You never know how literally someone may take your advice.
Old Apr 14, 2013 | 12:40 PM
Car: 1988 base
Engine: 305 tbi
i know my vacume hoses are messed up, the connections fall apart somtimes....that would cause it?
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
