Whyt engine RPM's so high on freeway...???Cant figure it out?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright you guys so I kow ive asked this question before but I ditn really get an answer...
The thing is this..When I am on the freeway going at about 70-75 MPH....my RPM'S are at 4000...I know for a fact that I have a stop non posi rear end and that my tach is wired up correctly and everything...becuase I rev it to 4000 and it sure sounds like it.....so I more than sure that the tach is not off. So I am really not sure my car is reving so high...The base timing is advanced by 12 degrees, My car is literally reving at 5000RPM'S if I wanna even go 80MPH on the freeway it sucks because I wanna go fast but Im afraid Ima "blow" the engine....
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
Re: Whyt engine RPM's so high on freeway...???Cant figure it out?
I have this same issue I put a new ATK motor into the car and it does this. I usually cruise at 72
Car: 1984 Z28
What ar your RPMS at 72?
These "tach"s are notorious for failing; after all they're not an "instrument", they're just a "trim package". Their usual failure mode is to read WAY high. I have one in my pile that reads almost twice what it should, and others here have reported them reading 3 times reality. So yours fits right in; sounds like it reads between 1½ and 2 times actual engine RPM.
Check it against a piece of actual test equipment.
Car: 1992 Camaro RS
Engine: 1978 L82 355
My aftermarket tach shows 3000 when my stock shows 4500ish.
Car: 1984 Z28
My stock tach is way off i knwo that part but I wires an aftermarket tach and it showing 4000RPM and its wired correctly...
Car: 1984 Z28
Car: 1984 Z28
I checked and it was set to 4...I set it back to 8 and when I drive it wont pass 3000RPMS...?? if it does the engine sounds over reved....
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Are you shifting into 4th gear? Can you feel it going through all the gears? it might be staying in 3rd gear if the rpms are as you say.
Engine: 4++,350 & 305 CIs
His info says he has a 5 speed...
reading comprehension ftf. OK, then either his clutch is slipping mad, or he has a tach issue for reals.....Or he hasn't learned o shift past 3rd gear
The 5 speeds are like 3.08 rears correct? My 3.73 rear with 24" tires and my 700r4 spins 2500 at 70. I would think a 5 speed should be turning 2000+- , half of what his tach says
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Either the tach is off or you are geared differently then you think.
Car: 1984 Z28
Well I am still confused onto what can be going on whats a normal RPM range when driving down the freeway at 75PMH in 5th gear?
For a typical LG4/T-5 car w 2.73 or 3.23 gears, around 2200 - 2400 RPM
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Are you sure the previous owner didnt swap a lower gear into the rear? An easy way to check is jack up the back of your car and mark your driveshaft and a tire, then rotate the tire a full turn and have some one count the drive shaft rotations. This will give you your ratio. Im pretty sure lol, hope this helps.
Car: 88 IROC
Then measure the diameter of your rear tire. Take that information and plug it into an rpm calculator. (google search)
Then you will know.
Car: 1984 Z28
You guys are right that the only way I will knwo....I know for sure thats its a non-posi, but lets say I do have higher gears..will that explain the high rpms?
are you running 12 inch trailer tires in the back?
you either have 4.xx gear ratio or a bad/incorrectly installed tach
my money is on the latter
Car: 1984 Z28
I wanna say that its the tach thats wrong but When Im driving the engine even sounds/feels liek its at 4000RPMs..So I am not to sure that the tach is wrong....
Agreed even with different rear gears you shouldn't be turning anywhere near 4000 rpm. Unless you have some crazy rear end ratio like 5.xx:1 or really smalll tires. What size are your rear tires? Need to verify correct tach operation first Engine will really be screaming at 4k rpm Do the test to determine your rear end ratio then by jacking it up and seeing how many revolutions the drive shaft turns with one rev of tire
Car: 1984 Z28
Like ive said I really hope its the tach that I wired wrong but....Ima do lift up the rear and do th test either way.
get a timing light with integrated tach. Have someone tell you what the tach shows in the cluster and then compare with the timing light
you're going to be shocked
If I was the betting kind, I'd bet that a tach that says your motor is doing low 2000s on the freeway, is substantially accurate.
I think you're wasting your time and effort carrying the matter any further.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
