this is a good 1,,,,need help
Old Feb 7, 2013 | 01:14 PM
SILLYBILLY's Avatar
I have a 91 1500 4x4. the truck runs well and shows no codes. Say i have a half tank of gas, when i get on it from a dead stop it boggs out after moving about 10' but comes right back and drives fine the lower my fuel gets the the more it happens at all speeds. right now theres a 1/8 of a tank in it and i cant drive it without adding gas thats how bad it is. fuel pumps either work or they dont is what i have been told and it has a new filter in it. anyone have any ideas? thank you
Old Feb 7, 2013 | 01:30 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Re: this is a good 1,,,,need help
check the fuel psi with a gage. if low psi or you see the nedle mouving all around you ether have a leak or your regulator is bad.
Old Feb 7, 2013 | 01:55 PM
SILLYBILLY's Avatar
thank you,,,,may i ask where the regulator is located
Old Feb 7, 2013 | 02:04 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
also you level may not be accurate half may be less than 1/4 and 1/4 may be empty or almost there
and the pump could be on its way out too the fuel cools the pump and the lower it gets the hotter it can run
Old Feb 7, 2013 | 02:13 PM
SILLYBILLY's Avatar
lunati397 thank you...that had crossed my mind but from what i have been told fuel pumps either work or they dont. i think carattini might be on to something with the fuel regulator. i would really like to know where it is located
Old Feb 7, 2013 | 04:19 PM
1killerolds's Avatar
it's a 91 so it's a tbi engine. the pressure regulator is on the tbi unit. you can get a regulator repair kit for about 20 bones. Pumps can be bad and still run the engine. You can also check the fuel pump current draw by putting a meter in series with the fuel pump test lead jumpered to bat+ should be aroud 8 amps. the lower the current draw, the worse off the pump is. also, the hose between the pump and the sending unit assembly rots and will split leaking pressure back into the tank. You should put a gauge on it and check the pressure.
Old Feb 7, 2013 | 08:57 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Ditto on the gauge it will tell you if your pump is getting weak.
They usually just dont go out most times you get some warning and yours sounds like it has the symptoms of one. Checking that line for splits is a great idea also
Old Feb 8, 2013 | 12:49 AM
wbstearns's Avatar
Car: 01 s10 blazer and 89 bird
Engine: 383 with mystery cam - maybe
Transmission: t56 hopefully
Axle/Gears: 373 geared posi from 2002 z28
1killer beat me to it my 01 blazer had starting issues for 6 mos before the pumpfinally died im not goingto get into my "creative" engineering for when it didnt want to start
but my money is on fuel pump
Old Feb 8, 2013 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by SILLYBILLY
I have a 91 1500 4x4....
Billy, since this site is dedicated to 82-92 F-bodies, you might Google your truck for a site more appropriate to your needs.
Best of luck with your project,
JamesC
Old Feb 10, 2013 | 08:42 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
even though this is "thirdgen".org the amount of chevrolet tech knowledge on this site is soo great that we have surpassed almost every other chevrolet forum. it would be rude to horde the knowledge for those who only drive 82-92 fbombs.
Posted from Thirdgen.org App for Android
Old Feb 10, 2013 | 08:43 AM
Axle/Gears: 2.77
just a thought
Old Feb 10, 2013 | 10:05 AM
JamesC's Avatar
Sorry, those are the rules. If you have concerns and/or comments, please address them to our site's administrator, JT.
JamesC
Old Feb 10, 2013 | 10:31 AM
Blue1990camaro's Avatar
what size fuel tank? ur guage might be off, my 1990 454 ss c1500 has the big tank like urs should have and if i try to get on it from a stop under 1/3 tank it bogs and falls on its face, just low on gas is all most likely, i hate that about mine im bout to put a smaller tank in the damn truck lol, but when i only get 8mpg that might be a terrible idea!
Old Feb 10, 2013 | 02:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
JamesC
Sorry, flattery will get you nowhere. As James noted, this is for 3rd gen f-bodies. If the topic was limited to the TBI system, we might be able to accommodate the question on the TBI forum. But, not issues that do not relate to 3rd gens.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
