fuel lines
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Axle/Gears: ??????????????
fuel lines
I have done a search and just cant seem to find it. Im looking for a diagram of the fuel lines on a 1991. If anyone has or knows where I can get one please let me know.
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Re: fuel lines
no the actual lines and which one is which. The problem im having is I have fuel spitting out of what appears to be a vent line. so before I pull the tank to inspect I would like to have a diagram of how and what the lines are. I have a Chilton manual but shows nothing.
keep in mind this car was a tbi car and now its a tpi, don't know if that matters
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fuel lines
sounds like the vent valve is bad next to the tank or are you saying fuel is coming out of the evap canister ?
Engine: Lb9
Transmission: M20
Re: fuel lines
if the fuel is coming out of the ccp canister replace the filter ACDELCO Part # A478C
http://www.ebay.com/itm/ACDELCO-PROF...sories&vxp=mtr
Engine: Lb9
Transmission: M20
Re: fuel lines
I got it from the parts manual. Part number 17 is discontinued start looking at the junk yard or post in the wanted classifieds.
Engine: Lb9
Transmission: M20
Re: fuel lines
If you can purchase a vented gas cap it would do the same thing. The vent is a one way check valve to let air into the tank.
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Re: fuel lines
thanks man im going to find a vented cap and see what happens. thanks again now you got me looking for a parts manual
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
