Driveshaft Question?
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
I hope someone can help me out/send me in the right direction. I have an 82 Z28, The engine I put into it came out of a 86 Chevy Custom Deluxe, Along with the TH350 Transmission. I've been told that MOST cars have short shafts, and most trucks have long shaft transmissions and that I would need to have a new driveshaft made. I don't really know how to go about measuring it.
So my question is, is this true? and would a different shaft from a different vehicle fit it?
and how do I go about measuring what I am needing. The crossmember bolted up fine, just like it should have, no adjustments were made, but I was told the extra length is in the tailshaft
Transmission: 4L80E/4L80E
If the tailshaft housing is 6" long, you can use your '82 driveshaft. If the tailshaft housing is 9" long, you can use a later 3rd gen driveshaft (the more common ones).
A good reference chart:
Car: 1982 Z28
Engine: 388 SBC
Re: Driveshaft Question?
So I need to measure the tail shaft, and if it's 6" get the stock 82 length shaft, if it's 9" get the stock late gen 3 length?
Sorry, I'm not much of a transmission/driveshaft guru.
Car: 1982 Z28
Engine: 388 SBC
sorry to revive this, but I went and measured the shaft this morning, it wasn't the 6 inch tailshaft, it's the 9 inch one. So can anyone tell me the length of a "later model" third gen?
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
the 2 aluminum shafts I have ( I think they're 4th gen, but I think they are the same as 3rd gen lengthwise) measure 41" from u joint centerline to u joint centerline. the yoke is 6.25" from tip to centerline of front u joint. So that adds up to 47.25" from centerline of rear u joint to tip of shaft.
someone else chime in here, I thought the 3rd and 4th gen shafts are all the same length until you get to the 6 speed ...????
Engine: 4++,350 & 305 CIs
Car: 1982 Z28
Engine: 388 SBC
I keep looking around, I just can't find the length exactly, I'm having a friend make me one, is why I'm trying to figure out the length of the shaft I'm needing.
Thanks for all the help and replies
I was just measuring a factory shaft for you for reference purposes..... thought you already had a shaft and wanted to compare.
Most DS shops will have you measure the rearend U-joint saddle to the outputshaft of the the trans.
ambainb
Apr 25, 2016 09:21 PM
theshackle
Aug 23, 2015 03:49 PM
