Swap on Non Comp Controled Carb & Dist What do I do with ECM?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I am taking off the Elec Controlled Q Jet and Dist, Putting on a 650 DP and a MSD Dist what do I do with the ECM? Is it controlling anything at this point? Can it hurt Perf and Mileage?
Re: Swap on Non Comp Controled Carb & Dist What do I do with ECM?
I'm guessing your using a 5 spd? You don't have to do anything w/ the ecm, your check engine light will be on all the time. All you need is voltage to the coil to run the engine.
If your car has a auto trans, you'll need to find a way to engage the torque converter clutch, they make a kit or use a pressure switch for 4th gear only lock up.
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You can pull the entire ECM harness out through the passenger side fender and remove the ECM. It controls nothing now.
Car: 86 Z28
What about the fan and the Gauges? I only have put about 1,000 Miles on teh car in teh last ten years, I'll manage with the gas. I'll pull the bulb.
Car: 86 Z28
So if I remove the ECM all ogether the fan and such will still work? I just wasnt sure if they were controled by the ECM.
About 15 Years ago I installed a Summit 350 in this car and did away with all the Elec but left the ECM in place, I have been away from cars for many years doing other things and it is crazy the stuff you do forget. Thanks
Car: 86 Z28
Can I remove the sensors from the thermostat housing?
What are they for?
Does one control the Temp gauge? if so which one?
can I put it someone else?
I want to put a nicer one on there.
What are they for?
The two sensors are a Thermal Vacuum Switch (TVS) for the Early Fuel Evaporation (EFE) valve and the Coolant Temperature Sensor (CTS) that provides temperature signal for the ECM. The guage reads off of the sensor in the left cylinder head.
Car: 86 Z28
Same Place the Fan does or some where else?
Fan switch is in the right cylinder head.
Car: 86 Z28
Thanks, Its been years since I have worked on these cars, I used to know where everything was, But it is all coming back to me. I have done this swap before so I should know.
