Valve spring retainer question - *see pics*
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
In the middle of changing valve springs, retainers, and locks on a1988 LB9.
Using Comp Cams:
Springs: 983-16
Retainers: 751-16
Locks: 611-16
The question is, do I re-use the stock "oil shield" that sits inbetween the spring and the retainer? My guess would be no, since the retainer doesn't fit into the shield perfectly square. Without the shield, the retainer sits really nice and flat. Pics with and without shield attached:
Advice would be appreciated.
Thanks!
Using Comp Cams:
Springs: 983-16
Retainers: 751-16
Locks: 611-16
Thanks!
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Valve spring retainer question - *see pics*
ive been running without them for many years. i think it lightens the valvetrain too.
Engine: 4++,350 & 305 CIs
Yup, ditch them.
You'll need a decent spring shim for the exhaust valves if you remove the rotators..
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Thanks for responses.
Any estimate on shim thickness in order to compensate for deleting rotators on exhaust side? Heads are stock 14101081 and have not had any machine work done on the spring seat pockets.
ambainb
Apr 25, 2016 09:21 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
