Need help locating fuel filter on '84 firebird
Old Mar 24, 2013 | 02:45 PM
Dirty birdie's Avatar
Car: '84 firebird, '77 jimmy
Engine: 2.8 6 cyl, 350 v8
Transmission: Stock
Axle/Gears: Stock
I was hoping it would be in the engine bay but suspect it is under the car. My car never starts well from a cold engine and I have to baby it till its warmed up. Also on sharp curves I have stalled several times. Acceleration up hills is painful. I do not want to take it to a shop if I can do the job myself and gain learning experience. Have replaced the brakes and the tires (at a shop), now i feel that if i can change the fuel filter, update/ delete the catalytic and get the carb rebuilt ill have a faster and more reliable dirty bird. The engine is the 6 cyl 2.8.
Btw I have been viewing the board for a couple months but recently registered and this is my first post. I love the aerodynamics of the car and how it loves flying down hills. The white trash moniker of the firebird to me is nothing but industry driven snobbery belittling PO' folk who cannot afford a corvette. But with the lowly lies wisdom
Old Mar 24, 2013 | 02:59 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
Re: Need help locating fuel filter on '84 firebird
Mine was after the hard feed line before the cfi system. if you follow the feed line from the engine bay towards the tank you should find it somewhere. Search autozone.com or another parts site to get an idea of what you are looking for.
Old Mar 24, 2013 | 03:13 PM
Transmission: Stock
Axle/Gears: Stock
I don't have a jack but I'll drive up onto some bricks and see if I can't get under there and find it. I know it's a metal line going from the carb and you say it is between the engine and the cfi (catalytic?) so that's a start. I've got the fuel filter already, it is amazing that such a small and cheap part can be so important. Got to go to work now, will check back in the pm.
Old Mar 24, 2013 | 03:33 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
CFI is crossfire injection, its what my car was. My fuel filter was by the number 2 cylinder.
Old Mar 24, 2013 | 06:04 PM
ex-x-fire's Avatar
Its in the carb, behind the big fitting at the fuel inlet. It the picture its at the bottom.
Attached Thumbnails Need help locating fuel filter on '84 firebird-carburetor_usa025001.jpg
Old Mar 24, 2013 | 07:44 PM
Transmission: Stock
Axle/Gears: Stock
Finally!!!
Probably I can get to it just by taking the air filter off. Gonna try it tomorrow morning. I knew I joined this place for a reason
Old Mar 24, 2013 | 07:59 PM
ex-x-fire's Avatar
While you have the air cleaner off, check for vacuum leaks, make sure the choke pull off diapham opens the choke alittle (test the w/ a vacuum pump)& make sure theres no vacuum to the egr at idle (makes it idle rough & start hard).
Attached Thumbnails Need help locating fuel filter on '84 firebird-carb005.jpg
Old Mar 26, 2013 | 08:55 AM
Transmission: Stock
Axle/Gears: Stock
It was too much a bear to get off with regular wrenches, was beginning to strip, even a line wrench was beginning to strip it. Ended up using two vice grips did the trick. Very little fuel came out, and this was without either disconnecting the fuel pump fuse or the negative on the battery. The old filter was full of water and a red looking mud. The crappy fuel we're forced to buy these days...
Thanks everyone, next up for me will be changing the o2 sensor and rebuilding the carb (a friend is gonna help me remove and reassemble)
ps ex x fire, I did find one vacuum leak about a week ago - solved with a twig. Same goes for the truck.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
