Fluid leak on front of engine
Old Mar 25, 2013 | 10:42 PM
BlackBerlinetta's Avatar
Car: 86 Berlinetta
Ive recently built a 383 vortec and put it in my 86 berlinetta its been running fine with no leaks except a small power steering leak. It is the old power steering pump. Today I noticed all of my pulleys on the backside and the tie rods were covered in a coat of brownish oil it is also covering the bottom of my engine and the timing chain cover. The problem is i cant tell where this leak is coming from if its my front main seal or the power steering pump is leaking from the back. My oil is at the full mark and power steering is low but i thought it should be red if it leaks?
Old Mar 25, 2013 | 11:16 PM
wishoradream's Avatar
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
Re: Fluid leak on front of engine
Smell it, that should tell you. Power steering is hyrdraulic, oil is.. well oil. If your oil is full, it's not leaking oil. Sounds like time to get rid of the old PS pump. The way it sounds, thats the culprit.
Old Mar 25, 2013 | 11:48 PM
Car: 86 Berlinetta
Yeah I shouldnt have put that old pump on my new engine now its gonna be a pain to clean! Thanks for the help, How long does the break in last for my rings? I have probobly around 75 miles on it but smoke is still coming out of the pipes when i have it at around 2500 rpms?
Old Mar 26, 2013 | 05:19 AM
Is there a bolt in this hole?
Old Mar 26, 2013 | 07:48 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
With the rings these days it should have been broken in already..
Something isn't right someplace.
Old Mar 26, 2013 | 10:07 AM
Car: 1982 Z28
Engine: 388 SBC
Not sure if I can be too much help on the rings, my grandfather worked for GM for about 18 years, and told me on a new car don't hold a constant speed, fluctuate it for the first 2-3000 miles. So I've basically done that. Not sure if that helps, like I said this was awhile back
Old Mar 26, 2013 | 10:09 AM
Car: 1982 Z28
Engine: 388 SBC
As for cleaning, just get some degreaser, spray, hose, and you should be alright
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Exxon Limited
Aug 9, 2015 08:13 PM
