breaking in new cam xe262???
Old Mar 31, 2013 | 08:45 PM
blacknblue's Avatar
Hi
I understand that you run the engine about 2500 rpm for 30 minutes. But how do you check if all is aligned and good/right?
Old Mar 31, 2013 | 08:58 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Re: breaking in new cam xe262???
what do you mean by how do you check if all is aligned and good/right?
Old Mar 31, 2013 | 09:06 PM
CamaroRS_92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
If you're speaking about your valve timing, u'd know if the cam was out of time. It'd be misfiring. Other than that I'm not quite sure what you mean.
Old Mar 31, 2013 | 09:11 PM
blacknblue's Avatar
Sorry. Read in a few post to stop and adjust as needed and go right back to rpm for rest of break in?
never done a cam before
Old Mar 31, 2013 | 09:14 PM
Car: 92 Camaro RS
Engine: 305 TBI
I would imagine the adjusment they're meaning is if you didn't time it right and had a miss. Unless there's something I don't know about. I've never professed to be a cam expert lol
Old Mar 31, 2013 | 09:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's nothing to adjust. If the cam is ground correctly and the sprocket marks are lined up, that's as good as it's ever going to be.
You can use a degree wheel to degree the cam before you finish assembling everything if you like.
Old Mar 31, 2013 | 09:22 PM
blacknblue's Avatar
Oh ok. Thanks guys. I must have misread the info
Just want to make sure I do this right.
Do it once right way, do it forever!!
Old Mar 31, 2013 | 09:25 PM
Car: 92 Camaro RS
Engine: 305 TBI
No problem man. Much agreed, better to ask than to hack. Good luck
Old Mar 31, 2013 | 09:41 PM
blacknblue's Avatar
Engines not in yet. Just doing some homework!!
Thanks again guys!!!!
Jorlain
Oct 8, 2015 01:57 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Ranbo108
Sep 9, 2015 12:20 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
