Who's running Dart Iron Eagle SS heads
Old Apr 29, 2013 | 07:24 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
I just bought a pair. Was curious on what people here thought about these heads. how much I might gain?
1.6 rockers going on as well
Crane Cam already in
Old Apr 30, 2013 | 10:43 AM
Car: 1987 IROC-Z
Engine: 6.2L
Re: Who's running Dart Iron Eagle SS heads
This place sucks. Time and Time again the same results
Old Apr 30, 2013 | 10:53 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Yeah, that's totally going to get you a positive response..
You asked a vague question when we literally know 0 about what you have. Explain to me how that warrants a good answer? The lack of responses indicates you asked a bad question that isn't worth responding to.
Old Apr 30, 2013 | 12:50 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Gain over what heads? For all I know you have Victor Jr heads on there now.
Old Apr 30, 2013 | 07:39 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Don't know much about the newer dart heads but I have a set of the older first design of iron eagles on a 355 that turns mid 12's.
Old Apr 30, 2013 | 10:36 PM
Car: 1987 IROC-Z
Engine: 6.2L
Finally someone that gets "it"
thanks. So, I assume you like your heads? Ever dyno the car with those heads?
Old May 1, 2013 | 05:04 AM
1gary's Avatar
Attitude??. Here's your answer. There no one part that is going to make a difference on it's own.It is either a matched parts build or a jumbled parts turd.
Now if you want to learn something on here and open up to what you have,then more people then time you can spare will reply from qualified members.Other than that,the answers you get are no further ahead then when you asked the question.
Nuff said.
Old May 1, 2013 | 08:44 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Don't get all pissy because you don't get it.
Dart makes 19 different SS head PNs that will work on a SBC so don't get all pissed off because you gave little to no information.
Also crane makes more than one cam so we might want to know that PN as well. It could be anything from mild to wild we don't know because YOU did not tell us.
We don't even know if they are going on a 305.
You want to know gains without giving information then I would guess somewhere between -150 to +150 hp
Jesus you ask questions like my wife.
Honey my cars making a noise
What does it sound like?
I don’t know
When does it happen?
I don’t know
Does it happen while breaking?
I don’t know
Is it a clunking sound?
I don’t know
Is it a whirling sound?
I don’t know
Does it happen only at high speeds?
I don’t know
Low speeds?
I don’t know
So when does it happen!?
NEVERMIND YOU DON'T KNOW WHATS WRONG JUST FORGET IT!!!!!!!!!!!!!!!
Old May 1, 2013 | 06:48 PM
Car: 1987 IROC-Z
Engine: 6.2L
midas = butt hurt
zraffz= telepathetic brother from a different mother
I remind you of your wife? Tell her i said helllloooo
Old May 1, 2013 | 06:59 PM
midias's Avatar
midas = butt hurt
Not sure who midas is but he probably agrees you are to stupid to ask a question correctly. Stick to fart cannon civics they are more your speed.
Old May 1, 2013 | 07:03 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
heres a tip if youre interested in getting these, douchegloves
these heads are rebranded and sold as summit racing's house brand iron heads. they punch them out and put bigger valves in them.
still the same small 165cc runner flow about 10-15cfm less than vortecs on the intake
better chamber design vs oe heads, good dart casting quality
probably support 385hp MAX unported...
Old May 1, 2013 | 07:12 PM
Car: 1987 IROC-Z
Engine: 6.2L
Heres pictures of all my tuner's with fart cans. They go ZOOOOMMMMbrrrrr
Old May 1, 2013 | 07:13 PM
Car: 1987 IROC-Z
Engine: 6.2L
Douchegloves? Super good burn Brohiem
Old May 1, 2013 | 07:53 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
His information says 1984 5.0... why would he be looking into one of the cheaper sets of heads if he didn't have a relatively stock motor or at least stock heads on said motor?
And truthfully with just heads and no cam or rhyme or reason you WILL gain power with those heads over stockers. While the top of the motor is apart and since you have to adjust the valves anyway at that point, you might as well do a cam thats more appropriate for those heads too.
Old May 1, 2013 | 09:05 PM
Car: 1987 IROC-Z
Engine: 6.2L
Thanks again for your input.
My iroc has a 5.7l. I've posted info all over this site about the car. It has what is believed a crane 2032 cam? Not even sure. The previous owner did the cam and had swirl port ti heads on it....yuck
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
sailtexas186548
Jan 19, 2016 12:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
