no oil at rockers
Old May 16, 2013 | 06:13 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
no oil at rockers
Oil pressure gauge reads good 60psi, reads from top of block behind intake, one rocker arm has ok oil the others little to no oil. 1000 miles on motor. Any ideas?
Old May 16, 2013 | 07:24 PM
joshc's Avatar
Car: 1986 Trans Am
Re: no oil at rockers
They should not be pouring out oil, just a dribble.
I would say plugged lifters on an old sludge filled engine.
I don't know on a new engine. I cant imagine you got 15 defective lifters. (I assume you got new lifters).
Did you check the pushrods to make sure they aren't plugged or packed full of assembly lube?
Old May 16, 2013 | 07:43 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
No i havent checked but its got 2 oil changes plus break in oil change and bout 100miles ago oil was flowin good.
Old May 17, 2013 | 07:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
How little oil is no oil? At low idle, there should be very little but still should have some oil. It will probably be messy but see if any oil gets to the top at around 1000 rpm.
Old May 17, 2013 | 08:40 AM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
No oil is zero oil nothing nadda zip no where to be seen, if i recall it was #3 exhaust had some and it was so little that when i had them fancy clip on rocker oil deflectors to adjust the rocker arms that got no oil aswell, oh hydraulic tappet cam and that was around 800rpm i can try bumpin to 1200. The top end used to have good oil at 500rpm.
Old May 17, 2013 | 08:49 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
When you primed the oild pump before your first start up, did you get oil coming out the pushrods?
If not, then you should have investigated before start up.
If so, and not now, something has plugged an oil feed hole, access silicone sealer can do this.
Before you assembled the block did you clean it?
Old May 18, 2013 | 03:46 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Well i tried adding more oil to see if sump fell off or came loose, bumped rpms to 1200, now the one rocker that had oil is no longer getting oil. 60psi oil at idle when engine got to running temp psi would drop off next to nothing, mechanical gauge.
Old May 18, 2013 | 08:55 PM
joshc's Avatar
Car: 1986 Trans Am
Sounds like a spun or severely worn bearing.
Old May 18, 2013 | 09:16 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
No noises from engine so i am starting to think the cam bearings never got replaced along with maybe a weak oil pump, supposedly the block is out of a 79 camaro so possibly original pump and cam bearings, idk.
Old May 19, 2013 | 08:27 PM
joshc's Avatar
Car: 1986 Trans Am
Yikes! Never do a rebuild without changing the cam bearings!
Oil pumps are also cheap for SBC, so I always replace them to.
Old May 29, 2013 | 06:38 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Ok got it all tore down, all bearings were new but not now, they are all scored cam bearings are worse, anyways should i worry bout the lifters gettin full of metal flakes?
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
