Power steering whine after 3 pumps
Old May 19, 2013 | 06:03 PM
tubesncubes's Avatar
Car: 88 GTA
Engine: 2001 ls1
Axle/Gears: TNT 8.8
I've got a 96 lt1 m6 trans am and after I swapped the short block (#8 spun) the power steering decides to whine. It has 100% functionality and turns like normal, but it whines like its low on fluid from the moment it lights. This is the 3rd pump (from NAPA) and I've bleed every one properly but they all whine. I even tried the Lucas stuff.
I've searched lt1ls1, ls1tech corvetteforums , and here and haven't found any substantial fixes.
What next? Nothing has fixed it or even remotely helped it.
Old May 19, 2013 | 06:37 PM
nickyakker's Avatar
Car: 1982 Firebird T/A
Re: Power steering whine after 3 pumps
Maybe you got dirt in the hose and something is causing it to restrict flow...??
Old May 19, 2013 | 06:43 PM
Car: 88 GTA
Engine: 2001 ls1
Axle/Gears: TNT 8.8
Possible, but not too sure about that, Its had fluid in and out at least 5 times with three pump installs.
Old May 20, 2013 | 08:21 AM
OrangeBird's Avatar
Car: 1989 Firebird
You mention swapping the engine , and then this problem happening with three different pumps . This gives me the idea that during the engine replacement , one of the power steering lines got crushed or kinked and is now restricting the flow of fluid , causing the pump to starve for fluid and whine .
Inspect each and every inch of the power steering lines between the pump and steering box (rack maybe ? I'm not sure what a '96 uses for steering components) and look closely for any kinks , bends , or dents that don't belong in the lines , and I'll bet ya find a mashed one .
Old May 20, 2013 | 05:25 PM
Car: 88 GTA
Engine: 2001 ls1
Axle/Gears: TNT 8.8
Did that when I put the motor back in, there is only one hard line that could be in jeopardy and it's accounted for as I pulled the body off the motor.
If the line was kinked the steering would be stiffer, but it's normal without any resistance.
Keep in mind it acts normal, but just has a whine.
Old May 21, 2013 | 10:21 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
when using a newer pump with the older steering box you will get the whine because the difference in flow and pressure its fine and will not wear the pump out mine ran for years without issue just did a monte carlo with a LS it does the same and a 72 chevelle and it does the same
Old May 22, 2013 | 12:01 PM
1killerolds's Avatar
Are you sure you have all the air out of the lines? Sometimes it can be a real PIA to get all the air out. Been there. If you are absolutely positive that there is no air in the system, my recommendation is to use a new GM pump. I searched my fix database of emails from IATN (international automotive technician's network) of over 10,000 fixes because I remember reading about guys having problems with noise after installing reman pumps. I found 10 emails about it. The only fix was to use a known good used pump or a new GM pump.
Old May 27, 2013 | 10:47 PM
Car: 88 GTA
Engine: 2001 ls1
Axle/Gears: TNT 8.8
Update:
Just flushed and replaced the aftermarket fluid with GM cold climate #12345867 ($20.93). jacked the front up, turned the wheels lock to lock, started it and........ still makes noise.
Ill see if it clears out in the next few days and if it does not stop then I get to make a trip to the salvage. I guess I'm getting good at pulling off pumps.
Old May 27, 2013 | 11:00 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
you could always install a blower with strait cut gears.it will cover the pump sound up
Old May 29, 2013 | 03:45 PM
Car: 88 GTA
Engine: 2001 ls1
Axle/Gears: TNT 8.8
Ha, funny.
I bought this car with the intention of selling it.
Old May 29, 2013 | 04:17 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
I have basically the same issue, replaced my pump , flushed, put Lucas pwr steering fluid, still whines
Old Jun 1, 2013 | 10:31 AM
Car: 88 GTA
Engine: 2001 ls1
Axle/Gears: TNT 8.8
Yeah, Im on the fence about running ATF instead of my $20 cold climate.
Old Jun 1, 2013 | 01:11 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Update:
It helps to have the engine running while you do this, not after.
Old Jun 8, 2013 | 07:36 PM
Car: 88 GTA
Engine: 2001 ls1
Axle/Gears: TNT 8.8
It's DONE!
Here's the story: When I put the power steering bolts in the first time, the last turn to torque it down felt soft yet it was snug.
BUT what I didn't know is that after swapping out pumps a few times the threads were getting weaker and weaker.
So after attempting to swap out the fluid for ATF this weekend, I decide to helicoil the bracket and that did it!
Its all quiet now
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
