Braided Fuel Line
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Braided Fuel Line
Looking to do my lines from the rail to the hard line in braided. My question is what brand have you used? Looking at Aeroquip, Russel, Earl's, Summit and JIC 37* generic fittings/line.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Braided Fuel Line
I've used a mixture of different fittings and brands. I've used most. Main thing is to pay attention to colors and fitting shapes. If you're a perfectionist they are usually different.
Transmission: Pro-built 700R4
Do you have any pics?
Car: 86 IROC
Axle/Gears: BW 3.27
Plan is to make up two lines with all the same manufacturer fittings/line. I don't plan of mixing. The issue is that they range in price. The JIC is the cheapest, followed by Summit then Aeroquip. Russel and Earl's are basically on par. Are Aeroquip fittings and line good, or do you get what you pay for?
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 86 IROC
Axle/Gears: BW 3.27
Bringing this one back. I am about to put together my lines and want to know. Is there an issue with mixing brands between line and fittings? I plan to use Aeroquip PTFE line, but limited to fitting angles.
Engine: 383 SBC
You shouldn't have any issue as long as your fittings are for the hose type you plan on running.
There was an article in Car Craft or Hot Rod few months back, maybe last year comparing fittings showing color differences and slight design differences.
Here's the online link to the black ones: http://www.hotrod.com/techarticles/h...s/viewall.html
The magazine covered the red and blue ones which some brands mix colors on their fittings.
I mixed Jegs, Summit, Russels, Earls, and Aeroquip fittings with my Aeroquip braided lines. You can tell a difference with side by side comparison, but unless you actually get close enough to look you might only tell the color hues are different.
The only reason why I used Aeroquip lines was a bundle deal at the time. Buy so much feet of lines get free aluminum vice jaws, which I gave some away to my friends since I ended up with several pairs.
Car: 1989 Camaro IROC Z
Engine: 383, soon to be an LS Stroker
Transmission: 700R4 - Switching to 4L80E
Axle/Gears: 10-Bolt/3.42 will be Moser 12-Bolt
I recommend calling the manufacturer's and asking their Tech Dept. people.
Of course, they will recommend their own parts. However, if you approach it from being a car owner who just bought a car with some "mixed" components, you'll come closer to getting a "straight answer".
I've been away from cars for almost 25 years, but I am back now - LOL !
I believe that Aeroquip is the oldest of the manufacturers you mentioned, with Russell and Earl's coming along afterward. The rest of them are more recent to the market.
Good Luck !
Car: 86 IROC
Axle/Gears: BW 3.27
Thanks for the replies. My issue is I bought everything that I needed and now am finding that the angle for my feed line is not the way I would like it. The angle I need does not exist for PTFE lined hose from Aeroquip. So if I can get away with using a Russell or Earl's fitting than that is what I will do.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
