various issues
Old May 24, 2013 | 08:38 AM
KR81's Avatar
various issues
Hi guys, new here! Ive done a few searches which were helpful but still got a few things to ask. Hoping you guys can help me out!
I intend on spending several years restoring it to perfection, however there is much I don't know about these cars so I'm hoping some of you guys can help me out.
1. Can someone confirm if the cigarette lighter runs on constant 12v or supposed to be on accessories? As mine is constant. Fault or normal?
2. Headlights. I've read up a little on these. I've put three new little ***** in each motor and the gears seem to have enough on them but I still get the motors running for around 10 seconds after they go down.
3.I have what I believe are the original tyre size, 16" 245's. They seem to rub on the inside wall on a full lock. Does this happen to anyone else? Can this be solved with spacers?
4. Rear demister switch. When I press it the headlights dim and the idle drops... it doesn't stay on for more than a few seconds then idle goes back to normal.
5. Do these early models put out codes for system problems? Is there a way of doing diagnostic checks without tools? (on a car I used to have you could bridge two of the pins on the diagnostic cable input thingy under the dash with a paper clip and would give u any codes via the check engine light ie 12 flashes x3 equals everything is ok! hope u know what I mean)
Hoping someone can help out!
Cheers, Chris.
P.S Check out my album!
https://www.thirdgen.org/forums/album.php?albumid=7799
Old May 24, 2013 | 04:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: various issues
Everything your saying is normal except the headlights running 4 ten seconds when off.
When you turn the lights off they will run for a sec or 2 then be done. Did you look at the gear teeth on the polly gears?
Old May 24, 2013 | 07:48 PM
KR81's Avatar
Re: various issues
Yeah the teeth on the gears look fine. No wear at all.
Old May 24, 2013 | 08:01 PM
Re: various issues
https://www.thirdgen.org/service-eng...ht-error-codes
Remember what you were surfing the Internet with in 1985?
I thought not.
The computers in these cars were just as crude, by modern standards, as whatever you had on your desk in 1985.
Me, I had an actual IBM PC XT. Then in about 86 or 7 I got a Compaq clone; the first real "clone" there was. 20M hard drive, 640k or RAM. What a slow steaming bucket of ... yeah. THAT'S the era of what's running your motor.
Old May 25, 2013 | 08:56 AM
KR81's Avatar
Re: various issues
I thought not.
1985? Desk? I was 4 years old! lol. I know, these would be of the most primitive systems around. I actually found that error code page and yeah, tried the paper clip trick and nothing, lol, as in it didn't even flash the system ok (12 I believe? what is it with GM and 12 as system ok? The holden's here in Australia use 12 as system ok too) so I guess that's something else to add to my list!
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
