Vacuum line filter or check valve? Pic inside...
Old May 29, 2013 | 03:59 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Trying to figure out what this is connected to the vacuum lines heading to the cruise control and hvac? As a check valve it don't work when I blow through it but I have read on here it's a filter to.
Old May 29, 2013 | 10:00 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Vacuum line filter or check valve? Pic inside...
Its a check valve. it will blow thru 1 way and not the other.
Old May 29, 2013 | 11:30 AM
Tony89GTA's Avatar
Car: 89 GTA
Damn, I was afraid of that, I can blow and suck through it no problem. Guess the blower must have poped it over time.
Old May 30, 2013 | 01:34 AM
Tony89GTA's Avatar
Car: 89 GTA
Just letting people know you can pick up one of these check valves in the help section, everything is exactly the same as the stock one. I also ordered up a spare through GM part #15733271
Old Jul 5, 2020 | 04:06 PM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
I know this is an old thread but I wanted to add to it to help others further. Hopefully, what I learned today can help someone else.
I was looking to see if there was a diagram showing the orientation of the check valve and ran across one in my PDF manual. Figured I share the diagram with all. The check valve in question is located between items [1] Vacuum Tank, [2] Engine Vacuum Source and [3] Black Tube as seen in the diagram. Based on its purpose, when manifold vacuum pressure rises (under load) the check valve should close leaving ports [1] and [3] common while closing off [2] vacuum 'source', or the lack there of in this instance. This allows stored vacuum pressure from the Vacuum Tank to support the cruise control actuator (not shown) and A/C.
I've also added pictures showing direction of airflow as it relates to check valve position with Source Vacuum present and not.
Old Jul 15, 2024 | 08:48 AM
LML305's Avatar
Car: 1989 Iroc-Z
Engine: 6.0 LS
Bennett, on your "check valve closed" diagram, wouldn't the (1) and (3) arrows be reversed? Without manifold vacuum, wouldn't the vacuum canister be pulling airflow in the opposite direction than you're showing?
Old Jul 15, 2024 | 11:07 AM
The 2 "clear" or "white" connections are the same, functionally. Direction of "flow" depends merely on which one is connected to the vac reservoir and which is connected to the vac "loads" (cruise & HVAC). The same thing could be accomplished using a valve with only 2 ports, and a tee. You are correct though, as the diagram is drawn, the reservoir is connected to the one that's inline with the source and the "loads" to the one at a right angle, so those arrows would be pointing the other way under the "no source vacuum" condition.
Old Jan 23, 2025 | 02:51 PM
Keithb's Avatar
I think this check valve is the "missing link" I have been trying to figure out. I have a vacuum port on my intake that is capped off:
And I have what I believe to be the HVAC vacuum tube here:
I also have a hose from the charcoal cannister and cruise control thing that almost reaches the vacuum port on the intake.
The two loose hoses are 5/32" , but the intake port is bigger. Maybe not 3/8", but close. Maybe 5/16". The check valve shown above looks to have one port that is slightly bigger. Is this what I am missing here?
All of my engine vacuum hoses are intact, so I am thinking these must go together. The diagram above makes me think this, but I'm not certain.
Old Jan 23, 2025 | 06:19 PM
LML305's Avatar
Car: 1989 Iroc-Z
Engine: 6.0 LS
Check this out, this is how I have my check valve hooked up and my vents work properly.
Old Jan 24, 2025 | 08:50 AM
Keithb's Avatar
Awesome. I think that answers my question. I have a check valve coming today.
To anyone who may have this problem, the reviews for the Dorman part say it does not work. It's basically a tee not a check valve. I did find a GM one at Oreilly for about $6, which was cheaper than the Help! version.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
