cranks but no fire
Old Jun 2, 2013 | 07:57 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
cranks but no fire
car ran fine started perfect, water pump went bad. replaced pump and tstat
car now doesnt start. all connections are connected. i have fuel pressure i have spark, car was just timed before water pump was changed out. .
Old Jun 2, 2013 | 10:27 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: cranks but no fire
Thats wierd, I'm in the process of changing my water pump out also, pumps out now, did you knock off the TPS or IAC plug ? or CTS ?
Old Jun 3, 2013 | 01:53 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
no and all of those sensors are pretty new as well under 6 months and all connected good and clean connections. im at a loss right now with this one
Old Jun 3, 2013 | 09:19 PM
Car: 90 Iroc Vert
Engine: 5.0L
Is it possible to have knocked the timing out when loosening the pulley bolts w/ belt on ? I'm at a loss as well.
Old Jun 3, 2013 | 11:51 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
i went ahead and rechecked everything. and as of right now it appears i have no spark. i found a burned fused, replaced it and my dizzy. cap. rotor. wires. plugs are all new. so i went ahead and changed out the ign coil too ( why not) but im still getting no spark anymore to my plugs? ive never had to look farther back to figure this out. my bat is only a month old and good on power. where do i check next
Old Jun 4, 2013 | 02:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
i have no spark.
New components doesn't necessarily mean working; wiring / connections / grounds also in play
read Pg 1 -6
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Jun 4, 2013 | 07:01 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
i have a little exp with with testing electrical. so this is what i got. i connected my plug straight to my coil and still had no spark. i check voltage to the coil pink and white wire to neg on battery. i got 8.50 then jumped to 2.6 then to open line. and repeated that. not getting a solid 12 volt. so is there a broken line somewhere. im looking at my wiring diagram, showing that its powered through the distributor.
Old Jun 4, 2013 | 07:47 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
read Pg 1 -6
That's a fantastic article...nice work!
Old Jun 4, 2013 | 08:17 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
still had no spark.
i check voltage to the coil pink not getting a solid 12 volt. so is there a broken line somewhere.
Nope.
Power to coil Pos terminal is straight from the Ign switch.
Run a temp wire direct from the Batt + terminal to + coil terminal and see if that solves the problem.
If it does,you need to check the wiring from the Ign switch or the switch itself may be kaput and only giving limited voltage out
FWIW
when checking car voltage; you put one probe ( blk ) on the batt neg or a ground like the engine block and other probe ( red ) on the wire being tested
Old Jun 5, 2013 | 01:34 PM
smittyakalance's Avatar
Car: 1991 Z28
Engine: 383 Stroker with edelbrock heads
Axle/Gears: 4.10 Posi
check the wires on your starter some of them going to ignition should be on there
Old Jun 7, 2013 | 07:12 PM
Car: 90 Iroc Vert
Engine: 5.0L
Just finished water pump and it fired right up, definately not related.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
skinny z
Oct 5, 2015 06:23 PM
