how much timing is too much
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
im a little confused on the distributor part of the timing sequence. i got my base timing at 14, and by 3000rpm im about 38 degrees. i have no vac advance so its just mechanical. is that to much? its for motor in my sig. i have msd 6al and accel distributor cap. any help/enlightmnet is appreciated
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: how much timing is to much
without knowing what heads, cam, compression, etc, it's impossible to determine how much is "too" much, but generally turn it until it knocks, then back it off a couple degrees. I know that with the 461 fuelie heads on my 350, even with my fairly mild cam and flat top pistons I couldn't get any spark knock no matter how far I pushed it. I think I ran it at 40 degrees of total timing. With my new Vortec heads, I expect to use considerably less timing, probably 33-34 degrees total. Heads, and your dynamic compression both play a huge roll in how much timing you can run, plus how much timing you'll actually need.
Engine: 355
edelbrock performer cam
air gap intake
670 street avenger carb
and believe 9.8-10.1 compression
i have it at 14 and my car runs really hott, so im not sure if i should bump it down or not. i had it at 20 advanced and never had a knock but starting and what not was a joke
The engine knows what it wants. It pays no attention whatsoever to whatever #s you think you are getting according to however you are getting them.
"If it RUNS good, it IS good".
The corollary being, if it RUNS BETTER some other way, then the other way IS BETTER; and if it RUNS WORSE some other way, then that way IS WORSE.
This is not rocket science. People get all hung up on "you have to run exactly 8.63° or the matter will come into contact with the anti-matter and annihilate the known universe in a giant black hole". They think they know better what your engine wants, than your engine does. What arrogant pompous ignorant blowhards. Ignore them and GO WITH WHAT WORKS BEST.
Your #s sounds about right, as far as they go; but then need about 12 - 15° of vac adv on top of that.
Get the vac adv working. You NEED it. The car will run cooler, have better throttle response at hwy speeds, and will get several more mpg on the hwy.
Engine: 355
Correct; no vac at WOT.
Vac adv is for CRUISE conditions.
Piece o vacuum hose
Yes.
If you actually just hacked it off for whyever, then putting it back would be a great start. If it's not appropriate then maybe you should take the next step.
how to i hook up the canister?
should i buy an adjustable or put the old unit back on?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i hve 210 cc 2.02/1.60 heads aluminum
air gap intake
air gap intake
Engine: 355
it wasnt hacked of it was takenof properly. im prob going to purchase the crane cam one since it comes with everything plus the springs.
