starter issue
Car: 84 z28
Transmission: t5
starter issue
ok i have a 84 z28 5 speed. I built a 350 for the car and put it in and the original starter is the straight pattern and the block i have doesn't have the straight pattern. So we got the diagonal pattern to fit but it doesn't catch the flywheel so my question is does anyone know how to get around this and get the diagonal pattern to fit and work? I thought my motor had both patterns but obviously it didn't. any help will be great this is my only car to drive.
Tony
Tony
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starter issue
http://www.summitracing.com/parts/csi-100psbp
or drill and tap the 3rd hole in the block
You can't ,the staggered pattern is for the larger 168 tooth flywheel ; you have the smaller 153 version
TheTraut88
Sep 7, 2015 05:22 PM
