Distributor Gear Wear
Old Jul 16, 2013 | 04:07 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
Recently I replaced distributor gear with a GM melonized gear. The cam is a ZZ4. So this is the recommended gear. In about a month the coating on gear has worn away in spots.
My question is once the coating is gone will the gear wear faster? I used to use bronze gears on the distributor and got 2-3 years of service each gear change. I'm thinking I should play it safe and switch back to bronze. A poly gear isn't made for the .427 distributor shaft.
Old Jul 16, 2013 | 04:29 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: Distributor Gear Wear
I'm not sure if the gear will wear faster or not once the hard coating is worn down, but that really isn't the main problem. The big issue is that if the distributor gear is wearing down like that and getting chewed up, then what is happening to the cam gear? The distributor gear is cheap and easy to replace, the cam gear is not.
If you are using a high pressure or high volume oil pump they can put extra stresss on the distributor gear and cam gear.
Old Jul 16, 2013 | 05:38 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Oh boy I get to crawl on top of the engine to check out cam this weekend. I'm hoping I just forgot to lube the gear when I took it out last time.
Old Jul 16, 2013 | 11:11 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Turning it over by hand will lube the gear. Dont worry aboutthe coating. Evey gear will wear in a bit Id say if your bronze one lasted a steel gear will last many yrs.
Old Jul 19, 2013 | 12:32 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
I couldn't even see the cam gear. The dist gear has some ridges on a couple teeth. I'll just keep my eye on it, maybe check the gear once a month. If the gear is steel it should last, iron will probably deteriorate pretty quick. I may just change back to bronze for peace of mind.
After cutting a slot above the gear I notice my oil pressure is now 40-50, instead of 60, so right there, the gear should last longer.
Thanks for your help.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
