Water Pump Problem
Old Jul 17, 2013 | 09:35 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Water Pump Problem
I already bought an aluminum HV water pump for a pre-1987 chevy 350 (which I found out upon installation) and I needed a water pump for 1987-92 serpentine set up. I found out that the water pump fits after I sawed off the extra bolt mount on the bottom right side of the pump. Will this work without a problem on my serpentine set up even thought in was for a pre-1987 v-velt set up? I thought all the chevy 350 water pumps before 1993 had the same rotation...
Old Jul 17, 2013 | 09:46 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Water Pump Problem
the water flow will be the correct direction,but water flow will be reduced a lot vs correct rotation.The hub bolt circle will be wrong too.AFAIK,all '88 up SBC and 90*v6 besides inboard boat are reverse rotation.
Old Jul 17, 2013 | 09:53 PM
$50 down the drain
Old Jul 17, 2013 | 10:53 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Can you take the pumps apart & swap impellers?
Would that work?
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
