Correct Pushrod Length for Procomp Heads?
Old Jul 19, 2013 | 12:35 AM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
I am putting together a budget built 1989 L98 roller motor. I know the stock pushrod length is 7.200, what size pushrods do I need when using procomp heads with 1.6 self-aligning roller rockers (w/o guideplates)? Is it 7.300 or 7.400? Superchevy was using 7.400 with stock self-aligning rockers. I saw 7.300 on other posts in the thirdgen forum. Which is correct?
Old Jul 19, 2013 | 06:28 AM
Re: Correct Pushrod Length for Procomp Heads?
The ones that produce the best geometry on YOUR heads mounted on YOUR block using YOUR head gasket with YOUR rockers and YOUR cam. Only way to know that, is to measure.
Old Jul 19, 2013 | 08:12 AM
Well, how do you measure? 7.200 fits, 7.300 fits, and 7.400 fits. Is the best geometry a visual term or is there a correct angle mentioned in the book for rebuilding a sbc?
Old Jul 19, 2013 | 08:44 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.lunatipower.com/Tech/Valv...nGeometry.aspx
Old Jul 19, 2013 | 09:18 AM
Thank you, that helps. Need +.100 or 7.300.
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
