oil pan
Old Jul 23, 2013 | 09:46 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
oil pan
My oil pan gasket is leaking its the blue felpro 1pc gasket. I put it on with the engine out. Can I take it down with the k member in the way. Or do I have to undo the motor mounts and push the engine up
Old Jul 24, 2013 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: oil pan
If your engine mounts aren't sagging too much, you can get the pan out if you turn the crank so the front counterweights are out of the way.
It's a lot easier if you pull the mount bolts and raise the engine up a little, though.
Old Jul 25, 2013 | 05:12 PM
Sojer's Avatar
Re: oil pan
Bullshit I cant clear the flex plate if I had the smaller one maybe
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
