Car cranks but no start
Old Jul 25, 2013 | 01:51 PM
91formula74's Avatar
91 Formula 305 tbi.. Sat for a month. Went to start and nothing but cranking.
New ignition control module and ignition coil, plus a new fuel pump relay.
Motor cranks, but doesnt start. I see no fuel spray from injectors and with starting fluid, nothing.
What should i do next? Car ran just fine a few weeks ago !!!
Old Jul 25, 2013 | 03:28 PM
Re: Car cranks but no start
Thank you in advance for any help !!!
Old Jul 25, 2013 | 04:13 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Is there spark? A check engine light? If both spark and fuel are out I'd assume a bad ecm or a bad connection somewhere.
Old Jul 25, 2013 | 04:15 PM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
Have you checked if you got spark? .. if not, then I would stab me a screw driver in 1 of the spark plug wires and have some one turn the engine over. if you get shocked then. yeah you know the deal.
Old Jul 25, 2013 | 04:25 PM
Havent checked spark since replacing ignition control module and coil . I thought replacing that would do it. Not even so much as a start with starting fluid and new parts. Hope I dont have to drop tank for new pump and sending unit.
Old Jul 25, 2013 | 04:43 PM
Shep5B's Avatar
nope. you know. you could just need a tune up. (plugs,roter, wires)... if you said you tried using started fluid and it didn't even make a stutter to try and start then it aint fuel.
Old Jul 25, 2013 | 06:09 PM
Thanks, I will try that.. Fed up is all, Never gave me a prolem since I bought it. Am the 2nd owner since 91!!'
Old Jul 25, 2013 | 09:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Havent checked spark since replacing ignition control module and coil . I thought replacing that would do it. .
Always test ( especially if replacement parts changes nothing) Never assume.
You may have screwed something up when replacing parts or got faulty parts.( not uncommon these days )
Not even so much as a start with starting fluid .
That is the big indication you have NO SPARK in the clylinder
A Ign system diagnostic work through like this can help identify where you have a problem
Read all 6 pages of tests
http://easyautodiagnostics.com/gm_ic...n_module_1.php
bryan623
Mar 22, 2021 06:43 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
92projectcamaro
Aug 6, 2015 01:20 PM
