85 IROC-Z Tach too high
Car: 1985 iroc
Engine: 305 tpi
Axle/Gears: 273
My speedometer reads 60 mph and the tach reads 4500 rpm.
Started out reading 60/30. Then 60/35. Just keeps getting higher.
The engine does not feel any faster at all. Please give advice?
Do I need to replace tach and if so where to buy?
Car: check
Engine: check
Transmission: check
Re: 85 IROC-Z Tach too high
There is a sticky on the Electronics board here that covers bad tach's. IIRC, the title is for the newer ones, but it may apply to your '85. If so it is an easy fix.
RBob.
RBob.
Getting hard to find good ones that way...
I have a whole HEEEEP of em. EVERY ONE reads high. One of em reads almost 3 times reality. The one in my car reads the least high; only about 3%.
Take RBob's advice on this one.
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
There are repair services available, but they are pricey. I sell refurbished tachs for $45. Let me know if you are interested.
Thanks, Greg
Thanks, Greg
Car: 1987 Iroc Z
I have a thread that shows my current inventory. Let me know which one you want.
https://www.thirdgen.org/forums/engi...-sale-all.html
thanks, Greg
thanks, Greg
Car: 1987 Iroc Z
I just got 2 5500 redline tachs in. One has a 60 psi oil gauge and the other has an 80 psi oil gauge. Either one is $45 shipped, just let me know which one you want.
thanks, Greg
thanks, Greg
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
There is a thread on repair. It's very straight forward if you are proficient at that type of work. I did mine and it seems to be working correctly.
Make sure you find the thread that covers 89 & earlier tachs. Not the 90+ thread.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
