engine all of a sudden reving on its own then stalling
Old Sep 3, 2013 | 11:51 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
hi i have a 1991 camaro rs with a tbi 305 just replaced all 16 lifters and replaced the distributor and it was running like it was brand new then a week later it starts reving on its own idle bounces and then it stalls wouldn't start for thirty minutes and then i was able to start it and drive it home still reving on its own so i replaced the idle air control valve and going to try and replace the throttle position sensor and see how that gos. if that dosnt work any opinions
Old Sep 3, 2013 | 02:51 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: engine all of a sudden reving on its own then stalling
Engines sometimes rev up when they are running out of fuel before they stall. Fuel pump relay or something like that?
Old Sep 3, 2013 | 03:25 PM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
would that still let it run bad for a little bit
Old Sep 5, 2013 | 07:07 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
i re timed the engine seems to be doing fine i have to wait and see because it was timed before
Old Sep 5, 2013 | 07:38 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Nope tried to start it this morning and it ran and then did the same rev up and then stall checked relay its good i can hear the pump priming its self
Old Sep 5, 2013 | 08:19 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
check your coolant temp sensor and the injectors.
Old Sep 5, 2013 | 05:50 PM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
both the coolant sensor and injectors are new replaced them a month ago
Old Sep 5, 2013 | 06:15 PM
maxjivi05's Avatar
First thing that comes to mind is vacuum leak...
Old Sep 22, 2013 | 01:04 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
found a leak on a hose going to start it tomorrow
and see what happens
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
zeitghaist
Aug 18, 2015 07:33 AM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
