Top end problems
Old Sep 7, 2013 | 04:55 PM
DannyG1974's Avatar
Top end problems
Have 1987 Chevy Camaro and built 383 motor. 11.1 compression products. 64 chamber heads. Holley dominator highrise intake. 750 demon dp. hydraulic tap cam specs: lift 502 intake; 238 exhaust. exhaust lift 516 intake; 244 exhaust. RPM range 3250 - 6750. Auto transmission w/3500 stall 410 gears. Tire size 28" ET drag.
Car ran 12.48 @ 113mph in 1/4 mile fresh off the motor. Car started slowing down since. Car now runs 13.18 consistent. Car crossed traps at no more than 5200 RPMs in 3rd gear. Is this a cam problem? what's caused the slow down?
Old Sep 8, 2013 | 09:44 AM
1gary's Avatar
Re: Top end problems
Danny-a leakdown test will reveal a ton.BTW-you never posted what heads are on this.
Old Sep 8, 2013 | 07:27 PM
DannyG1974's Avatar
It has Brodix Track 1 heads. What's a leakdown test?
Old Sep 8, 2013 | 07:47 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
A leak down test is pressurizing the cylinder with shop air and watching how much pressure it looses. Tells you if you have a leaking valve or bad rings or whatever.
Also have you checked the adjustment on the valves? Maybe now that its broken in something loosened up?
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 9, 2015 01:15 PM
