Tried Hypertech and JET coolant fan switch, both turning on at wrong temp.
Old Oct 1, 2013 | 09:57 PM
nakota2k's Avatar
Car: 1989 Iroc-Z 350
Installed a Hypertech switch (on 200F) a month back and both fans turned on at around 140 and just stay on pretty much all the time. Not wanting the fans to burn out I installed a JET switch (on 195F) and now the fans turned on at 160 and stayed on but now about a week later neither fan turns on except when the A/C is on they both run strong. Hard to believe both switches are faulty, don't know what to try next.
Old Oct 1, 2013 | 10:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Tried Hypertech and JET coolant fan switch, both turning on at wrong temp.
I installed a JET switch (on 195F) and now the fans turned on at 160 and stayed on.
Is your temp gauge accurate?
Given the AC uses the same relay(s) to operate the fan that would indicate a problem with the switch
Take the wire off the switch and touch it to the head.(Ign on )
If the fan runs , then the switch is the problem ; if it doesn't you have a problem with the wiring to the switch
Old Oct 1, 2013 | 10:22 PM
nakota2k's Avatar
From what I can tell, it is.
I'll try that. What about the coolant temp sensor by the thermostat housing? What role does that play? I've been under the impression the fan switch is the sole cause of my problem.
Old Oct 1, 2013 | 11:02 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The CTS gives the engine temp to the computer for it's operations
On a TPI, the fan is controlled by the computer and the fan on temp can only be changed by reprogramming the computer.
If you want to install a aftemarket switch like you are using ,custom wiring is needed to bypass the computer control
On a TBI , the fan is controlled by the fan switch with no input from the computer
Old Oct 1, 2013 | 11:11 PM
nakota2k's Avatar
Custom wiring? Never heard anyone doing anything like that other than replacing the sensor and splicing in a new plug >.<
Old Oct 1, 2013 | 11:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I second what Vetteoz said.
Single fan is only controlled by the fan switch. Dual fan set up, the primary fan turns on from the ECM, secondary fan turns on from the switch. Both should turn on with the AC.
Old Oct 1, 2013 | 11:35 PM
nakota2k's Avatar
So I'll prolly replace the switch again. Should I get a custom chip or new eprom as well? Not familiar with ECM stuff
Old Oct 1, 2013 | 11:53 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Custom wiring?
Dual fan set up, the primary fan turns on from the ECM, secondary fan turns on from the switch. .
I'm not up to speed on the individual 3rd Gen model differences between models but if the 2nd fan is controlled by the switch then that should be the only one running at the wrong temp off your new switch.
( unless the fan wiring has been modified to run both fans at the same time????? )
Old Oct 2, 2013 | 12:10 AM
nakota2k's Avatar
No wiring has been modified. When the switch was stock they turned on separately at different temps. The original wasn't bad, its just I live in AZ and wanted them on earlier for the heat we have here. With both new switches the fans go off and come on together. No idea
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
fasteddi
Sep 2, 2015 10:29 AM
NBrehm
Aug 25, 2015 11:49 PM
Fronzizzle
Aug 9, 2015 01:15 PM
