good deal?
Old Oct 17, 2013 | 08:09 AM
gilly327's Avatar
Car: 86 firebird se/91 camaro rs
Axle/Gears: 3:73/3:42 4th gen
good deal?
picked up two sets of 906 vortec heads from the u pull it yard for $125 after core tax enviro fee etc.wondering if this is worth the money.didnt notice any cracks on the heads
Old Oct 17, 2013 | 08:27 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: good deal?
Well it all depends on what value these heads have to you. It must have been worth it to you. Now, what projects do you have going that you will use them on?
Old Oct 17, 2013 | 08:40 AM
gilly327's Avatar
Re: good deal?
i have a 4 bolt 350 block and down the road was gonna just build it up for the street.i have a 350 in my 86 firebird now with trick flow heads so those are staying put.was basically just grabbing extra heads for down the road.figured id get all the vortec heads the yard had so once i take them to get checked out hopefully at least two heads are good
Old Oct 17, 2013 | 10:02 AM
1gary's Avatar
Re: good deal?
Crack prone in the exhaust seat area.Have seen used heads check out and then crack once put on another engine.
Old Oct 17, 2013 | 10:22 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: good deal?
Sounds like a good price. You should have no problems reselling them for more than that. If you decide to use a pair, you'll want to have a machine shop magniflux them to check for cracks. As you probably already know, these are prone to cracking because the trucks they came out of were notorious for overheating. From what I've seen & read, these heads are no more prone to cracking than any other head if put into a vehicle that doesn't overheat, so as long as your set checks out, I wouldn't have any worries about using them.
Old Oct 17, 2013 | 11:23 AM
gilly327's Avatar
Re: good deal?
thanks
Old Oct 18, 2013 | 06:58 AM
Re: good deal?
Kinda late to be asking NOW, isn't it? For better or worse, it's a done deal.
The "right" mental process would be to ask, what should you do now; not, is the water under the bridge, really gone downstream already. And the answer would be, get em cleaned up and see what you've got, then go from there. One step at a time... always looking FORWARD.
Old Oct 18, 2013 | 08:51 AM
1gary's Avatar
Re: good deal?
I do like the Vortec's for 350/355 street applications.I like the performance GM new heads much better where they are designed with 180cc intake runners exactly for those size engines.After you waste time and money on used junk.............the price of the GM performance heads could be cheaper.It is a pet peeve of mine that guys all the time want to cheap out on one of the most important part of a build.The cylinder heads.Not very smart.
hectre13
Dec 11, 2023 08:14 AM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ChevyZ71
Aug 13, 2015 07:30 AM
