Timing chain confusion! Need help!
Old Oct 27, 2013 | 01:33 AM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Hey guys i have a 91 z28 just took out all the TPI set up and swapping to carb. New heads and new cam are going into the build. So my problem is i have bought a cloyes double roller timing chain set but i am seeing that when im trying to install it, the cam sproket hits the plate for the cam. Do i have the wrong timing chain? Does the plate for the cam really have to be there? What do you all recommend thanks!
Old Oct 27, 2013 | 01:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Timing chain confusion! Need help!
Did you buy a timing set for a OEM roller cam engine?
Part # ?
The cam gear is different to that used for a non roller camshaft
It stops the cam walking out the front of your engine
Old Oct 27, 2013 | 02:07 PM
robg91z's Avatar
Engine: 350ci TPI
I believe its a cloyes c-3023x. Can you give me a part number on a double roller timing chain for my motor?
Old Oct 27, 2013 | 02:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
For a roller cam use cloyes Timing set p/n 9-1145
http://www.jegs.com/i/Cloyes/220/9-1145/10002/-1
Old Oct 27, 2013 | 05:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
"Will not fit factory roller cam applications".
You have to read the fine print when buying because even though a set may be listed for '87+ ,that time frame also included production non roller versions like crate and truck engines
Old Nov 3, 2013 | 01:25 PM
robg91z's Avatar
Engine: 350ci TPI
So is that cam plate really needed? Whats the difference of it having and not having it? And why doesnt the older blocks have it? Im just curious lol
Old Nov 3, 2013 | 01:57 PM
Engine: Lb9
Transmission: M20
A roller cam will walk without it, roller cams didnt begin to come in production engines sbc until 87. If you want to you can use a cam button to set up end play with a non roller block timing chain set but why !
Old Nov 3, 2013 | 04:10 PM
robg91z's Avatar
Engine: 350ci TPI
Oh i see. Yeah i was just curious but u answered my question thanks
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
MY87LT
Aug 17, 2015 08:43 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
