Repairing Headlight Motor. Replacing plastic bushings. Broken Bolts?
Old Oct 30, 2013 | 12:56 PM
GTA88's Avatar
Hi,
My car is an 88 TransAm. I've been looking around on the net, and found some neat youtube info on how to replace the crumbled delrin bushings inside the headlight motor.
I notice guys here on Thirdgen.org don't seem to have much of a problem with the whole procedure. But the other guys , in the youtube videos, end up breaking the bolts off when they try to remove the cylindrical cover to the brushes inside the motor. (The last 2 bolts that need to be removed, which are 1/4 inch head, I believe.)
Anyone have this problem? How did you resolve it? Drill out the bolts?
I REALLY don't want to have to drill out the bolts. Looks very awkward.
P.S. I haven't started this project yet.
Old Oct 30, 2013 | 01:12 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Repairing Headlight Motor. Replacing plastic bushings. Broken Bolts?
the passenger's side is easy..
the driver's side the bolt heads WILL snap off. I suppose you can try soaking them with PB blaster, let them sit overnight.
at the end of the day they are small bolt and will snap, if they do you drill them out.
if you buy the rebuild kit from Top Down Solutions it comes with all the parts to rebuild both headlight actuators.
It took me about 2 hours to do the whole project including drilling out the 2 broken bolts.
Old Oct 30, 2013 | 01:58 PM
GTA88's Avatar
FRMULA88,
Thanks for replying ! When you say the passenger side is easy, do you mean that you don't have to remove the 2 bolts we're talking about when doing the passenger side?
Old Oct 31, 2013 | 08:39 AM
FRMULA88's Avatar
Car: 1988 Formula
Originally Posted by GTA88
FRMULA88,
Correct,
On the passenger side you will not have to take apart the motor to dis-assemble the actuator, so the bolts holding the motor assembly together won't break.
On my car the passenger side wore out, but I went ahead and rebuilt both just on principle so they are both "new"
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Fronzizzle
Aug 9, 2015 01:15 PM
