Oil Leak help!!
Old Oct 25, 2013 | 03:17 PM
jrmints1415's Avatar
Car: 1985 Firebird
Engine: 2.8l V6
Transmission: 5 speed manual
Oil Leak help!!
Do you know where this leak is coming from? It pours out oil when I crank the car over. Looks like it's above the oil filter somewhere.
Old Oct 25, 2013 | 03:35 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: Oil Leak help!!
There is a threaded plug on the side of the block just above the filter. I would check this because it for an oil sending unit.
Old Oct 25, 2013 | 03:49 PM
Car: 1985 Firebird
Engine: 2.8l V6
Re: Oil Leak help!!
Here's a pic of it
Old Oct 25, 2013 | 04:41 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: Oil Leak help!!
That hole needs to be plugged up. You need an 1/8" NPT pipe plug. Any hardwar store will have it
Old Oct 25, 2013 | 11:44 PM
Car: 1985 Firebird
Engine: 2.8l V6
Re: Oil Leak help!!
What hole??
Old Oct 26, 2013 | 12:29 AM
Guest
Guest
Posts: n/a
That is such a giggity
Old Oct 26, 2013 | 07:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Oil Leak help!!
https://www.thirdgen.org/forums/tech...formation.html
If we had some idea of what year and engine it might help ................
Old Oct 26, 2013 | 08:59 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Oil Leak help!!
When you don't fill out your profile it makes it very hard for us to help you.
Old Oct 26, 2013 | 12:05 PM
Car: 1985 Firebird
Engine: 2.8l V6
Re: Oil Leak help!!
Sorry about that. It's a 1985 firebird 2.8l v6 fuel injected. It doesnt feel like the oil leak is coming from the filter it's coming from above it. Thanks!
Old Oct 26, 2013 | 07:21 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Oil Leak help!!
Check your oil pressure sending unit,... next guess is the valve cover.
Old Oct 30, 2013 | 11:18 PM
Car: 1985 Firebird
Engine: 2.8l V6
Re: Oil Leak help!!
so i replaced the oil filter, and oil filter adapter gasket and it still gushing out when i turn the motor over. No matter at what angle i look i cant see the source as its coming out, all i know is that it looks like its right above oil filter adapter and next to the motor mount. any help is greatly appreciated, im about ready to just remove the whole engine to find the problem...
Thanks!
Ryan
Old Oct 31, 2013 | 11:01 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Oil Leak help!!
You can clearly see in that picture a hole above your oil filter where the oil is coming out. Like i said before, PLUG IT.
Old Oct 31, 2013 | 01:32 PM
Car: 1985 Firebird
Engine: 2.8l V6
Re: Oil Leak help!!
I think ur talking about the drip of oil... if so thats not a hole.
Here is a picture of things i found---
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
