95 LT1 HEAD GASKET ALUM HEADS ??
Old Nov 1, 2013 | 09:41 AM
CBOYER's Avatar
Car: 85 z28
Engine: 95 lt1
I had my 95 lt1 from a vette down to the block . Heads were decked down and checked for the second time they have been off the block. I got the motor all back together for a few weeks all good no leaks sat in the drive way running prob a total of a few hours , took a few test drives engine up to temp no issues. lt1 is in a 85 z28 took it out the other night opened it up a to miles down the road and blew a head gasket . question is should i have a thicker head gasket and any one know the part # for lt1 arp head bolts . Was useing reg lt1 felpro head gaskets ? any help would be great
Old Nov 1, 2013 | 12:11 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: 95 LT1 HEAD GASKET ALUM HEADS ??
I doubt your issue is the gaskets. The heads on my lt1 have been milled several times and I am using the stock thickness felpro head gaskets. I am using arp 12 point head studs.
Old Nov 1, 2013 | 02:28 PM
CBOYER's Avatar
Car: 85 z28
Engine: 95 lt1
I think the temp was up 2 210 when it blew, are the heads syposed to be re torqued after the motor is run a few times . i thought is once and done. just ordered arp head bolts and new gaskets
Old Nov 1, 2013 | 03:43 PM
Car: 1990 Camaro RS
Nope they shouldn't have needed retourqed. Did you follow the proper torque sequence and to the correct number of final ft. Lbs? 210 isn't that hot I have had mine higher then that when my cooling fan failed.
Old Nov 2, 2013 | 09:43 AM
CBOYER's Avatar
Car: 85 z28
Engine: 95 lt1
Yes i used the directions from the lt1 rebuild book. hope tomorrow 2 have the heads off so i can see where it failed, im thinking its the # 8 cylinder
Old Nov 2, 2013 | 02:38 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Very interesting, please if you can take some pictures.
Old Nov 2, 2013 | 06:42 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
From what you said theres no reason it should have blown. I would pull the heads and actually look at where the gasket blew.
Are you certain you blew the head gasket? Have you pulled plugs? Checked compression? Coolant/oil mixing?
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
