What is this hole?!?!
Old Nov 2, 2013 | 06:18 PM
jrmints1415's Avatar
Car: 1985 Firebird
Engine: 2.8l V6
Transmission: 5 speed manual
I was looking around for an oil leak that gushes out when I crank the motor over and I think it's coming from the hole to the upper left of the oil filter adapter. Should I plug this hole or does it connect to something?? It looks like it's right across from a valve that I guess is for oil bybass but im not sure. Any help is greatly appreciated!!!!
Old Nov 2, 2013 | 06:27 PM
ex-x-fire's Avatar
Re: What is this hole?!?!
Looks like this one is plugged.
Old Nov 2, 2013 | 06:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Where is your oil filter ?
The pic above shows the oil filter adapter mounted to that hole
Old Nov 2, 2013 | 07:02 PM
Car: 1985 Firebird
Engine: 2.8l V6
I removed it along with the filter adapter to find the source of the leak
Old Nov 2, 2013 | 07:12 PM
Car: 1985 Firebird
Engine: 2.8l V6
So should I plug it or not, I think I should but not totally sure.
Old Nov 2, 2013 | 07:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is the hole threaded , the pic above appears to show a pipe plug (NPT ) sealing it ?
Old Nov 2, 2013 | 07:20 PM
Car: 1985 Firebird
Engine: 2.8l V6
heres a picture of what i mean
Old Nov 2, 2013 | 07:33 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Is this a V6? my 3.1 has the Oil pressure sending unit threaded in right there.
Old Nov 2, 2013 | 07:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
That is the pic you should have put up 1st with the hole dentified.
As noted ,does the hole have a plug in it?
If it does ,take it out , clean it and the hole well , then use some thread sealer on the plug when you reinstall it tight
Old Nov 2, 2013 | 09:09 PM
Car: 1985 Firebird
Engine: 2.8l V6
yes this is a 2.8l v6. If the oil pressure sending unit is the thing that has an electrica; connector on it then its on the housing that i removed. The hole is not plugged and am 95% sure it is threaded. Thanks
Old Nov 2, 2013 | 09:23 PM
ex-x-fire's Avatar
I can't believe this went on for so long, the picture I put shows it's plugged.
Old Nov 3, 2013 | 07:49 PM
Car: 1991 Camaro RS
Its just a Port to the oil passage....... if theres nothing that needs to be plugged in there. Then go ahead and plug the hole. Simple enough. Plugging it wont do anything but let the engine Recirculate the oil and allow the pump to build pressure like its suppose to....
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
