Low compression on two cylinders.
Old Nov 3, 2013 | 04:40 PM
fishhook86's Avatar
Car: '86 Camaro
Axle/Gears: Good question
I bought an 86 Camaro running a little rough and with a slight knocking sound. I checked compression and found:
1-97
2-185
3-180
4-180
5-86
6-180
7-167
8-180
I added oil to cylinder 1 and 5 and got:
1-100
5-90
When I started taking it apart I found cylinder 5's plug with a lot of built up carbon and the post on the distributor missing. (I'm hoping that was the slight knock)
I don't see anything around cylinder 1 on the block, head gasket or head that looks like a leak or any other reason for low compression. Cylinder 5 looks good other than the carbon build up on the valves.
Is there anything else I should check before I pull the pistons and replace rings?
Also, how hard (if possible) would it be to pull the oil pan with the motor in the car?
Thanks in advance for any help.
Old Nov 3, 2013 | 06:06 PM
ex-x-fire's Avatar
Re: Low compression on two cylinders.
If adding oil didn't improve the results, that indicates a valve sealing problem or head gasket leak. When adding oil improves that results, then its considered a ring problem.
Old Nov 3, 2013 | 06:08 PM
ex-x-fire's Avatar
It might have the rockers over adjusted, or carbon on the valves, or it might need a valve job.
Old Nov 3, 2013 | 06:18 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It looks like 1, 5 and 7 are suspect. They're all on the same bank.
Your oil squirt test points to valves. But before you do anything, I'd pull the valve cover and take a look there.
Old Nov 3, 2013 | 07:01 PM
Damon's Avatar
Tear the motor down. If the reason for the damage has been identified and repaired, that doesn't change the mechanical damage that has already been done as a result of that.
Old Nov 3, 2013 | 08:42 PM
fishhook86's Avatar
Car: '86 Camaro
Adjusting the valves didn't change anything. I've got some old heads off a 350. When I get a chance I'll throw them on and see if I get anything better.
Old Nov 4, 2013 | 11:56 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
if squirting oil improves the compression reading then the rings are worn/damaged.
rent or borrow a bore scope and take a peek into the cylinders with the low compression readings.
Otherwise do a leak down test on the two holes with low compression... if you hear air in the crankcase this will confirm the problem is related to the rings / pistons / cylinder walls.
air coming out the exhaust pipe.. the exhaust valves
air coming out the intake manifold.. the intake valves
Do a coolant pressure test to confirm the head gaskets are not bad, but if the car runs and not burning white smoke the head gaskets are probably fine.
at this point it makes no difference, the motor will have to come out and apart to repair so all new gaskets will be on the list of parts.
Old Nov 4, 2013 | 06:13 PM
fishhook86's Avatar
Car: '86 Camaro
I had that head off before my first post. I don't have an air compressor so I couldn't do a leak down test. The cylinder walls look good to me. Nearly no ridge at the top and the cross hatching looks good.
Old Nov 6, 2013 | 10:54 AM
Lynn1990IRocZ's Avatar
Car: 1990 Iroc Z
im gonna guess your probably is gonna be burnt valves, head gasket would show low compression on adjacent cylinders and the wet compression test shows the rings aren't your problem
Old Nov 6, 2013 | 10:55 AM
Car: 1990 Iroc Z
only way to know for sure really is take it apart or cylinder leakage though
Old Nov 6, 2013 | 12:47 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Get a pressure tester from your local parts store. Then using the tester, hook it to an air source. Make sure both valves are closed and pressurize the cylinder. If you hear noise through the intake....it's the intake valve. Vise versa for the exhaust valve.
I'm thinking you over adjusted the valves.
Old Nov 10, 2013 | 10:33 AM
fishhook86's Avatar
Car: '86 Camaro
I have a compression tester that I could use but I have no air supply. I lossened the valves until there was play in the pushrod and still didn't have compression.
Hopefully I can find the time today to put that other head on and see what the compression looks like.
Old Nov 10, 2013 | 11:07 AM
ex-x-fire's Avatar
That won't work, you need the valves to open to draw in air to compress.
New cars that have cylinder deactivation turn off the valve action to save mpg.
Old Nov 10, 2013 | 01:00 PM
fishhook86's Avatar
Car: '86 Camaro
That seems obvious after reading it.. lol
I believe I had them adjusted right before I did that though.
I put the 350 head on and got
1-45
3-120
5-60
7-130
So I guess it is a ring issue. Maybe I didn't get enough oil into the cylinder when I tried that test. (it was a pain to get any in)
I'll probably just put it back together with the 305 head and run it while I rebuild a 2 bolt 350 block I have in the garage.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
customblackbird
Oct 1, 2015 04:30 PM
327IROC85
Sep 23, 2015 12:11 AM
adelane
Sep 9, 2015 08:51 PM
