1991 Camaro 3.1 v6
Old Nov 7, 2013 | 09:55 PM
pinky101's Avatar
1991 Camaro 3.1 v6
1991 Camaro 3.1 V6
Car turns over well...tries to start...chugs along for a few seconds then dies. Won't take any throttle. After restarting a few times the car eventually clears whats wrong and runs great. It has never acted up while driving, only when starting.
Here is what has been done: New plugs, cap, rotor. ICM tested good. Last item replaced before I got it was the MAP sensor. Replaced IAC and TPS. I've gone over all the vacuum hoses...replaced bad/cracked connections...capped one open end down by the battery(for the cruse control- which this car doesn't have).
Fuel pump and filter replaced. Car started and ran great all summer. Then all of a sudden it started acting up again when starting(hot or cold). Just an occasional problem at first...got worse...then finally it just wouldn't start. Replaced the battery. Anyone had a similar problem, or have any ideas?
Old Nov 7, 2013 | 10:55 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 1991 Camaro 3.1 v6
Check your Fuel Pressure Regulator and ohm your fuel injectors. My V6 3.1 did this to me before my injectors went out on the highway. Check the link out. Good luck.
https://www.thirdgen.org/forums/v6/6...or-advice.html
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Cripley
Aug 17, 2015 03:35 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
