revving high when taking off? normal?
Old Nov 9, 2013 | 05:24 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
i just bought my first car a 1992 firebird 3.1 v6 and whne i take off it revs very high is it saposed to rev high? because its a 4000 lbs car beign moved by 140 hp?
Old Nov 9, 2013 | 10:09 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: revving high when taking off? normal?
your description sounds like the transmission is slipping-first check that tranny fluid is at proper level(should check level with engine running)add some fluid if too low.IF fluid ok,tranny may need repair.Do not drive with slipping transmission or you will soon need transmission repair...Curb weight of a v6 firebird is typically around 3200 LB-gross weight rating is about 4000LB IIRC;curb weight plus rated passenger and cargo load.
Old Nov 10, 2013 | 07:59 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
+1 for possible trans issue. You should have no problem taking off even if you do have a V6. Ive driven a 85 with a 2.8/auto and there are no issues at all.
Old Nov 10, 2013 | 10:14 AM
mikey8494's Avatar
Axle/Gears: stock
so when it revs in reverse and doesnt move till i floor it is transmisson
Old Nov 10, 2013 | 04:11 PM
mikey8494's Avatar
Axle/Gears: stock
ok heres a video of me backing it into the shop area and as tyou can seei have to throttle it alot to make it move. sorry for my crappy film manship
Old Nov 10, 2013 | 05:14 PM
mikey8494's Avatar
Axle/Gears: stock
bump
Old Nov 10, 2013 | 05:37 PM
mikey8494's Avatar
Axle/Gears: stock
http://http://www.youtube.com/watch?v=B-sq9uwT5z0
heres another one agian sorry for the shakyness im trying to focus on the rpm needle if you skip towards the end im back up and you can here it reving very high but barely movving.
Old Nov 10, 2013 | 05:59 PM
fishhook86's Avatar
Car: '86 Camaro
Axle/Gears: Good question
It looks like the transmission is slipping. It's pretty likely damage has already been done. Like someone already said, check the fluid level and when you do check to see if it smells burnt.
Old Nov 10, 2013 | 06:05 PM
mikey8494's Avatar
Axle/Gears: stock
it doesnt smell burnt and its bright red like new fluid. the po failed to tell me he told me mechanicly it was working just fine except a leaking radiator..damn i dont have the moeny for a transmission rebuild i dontk now if i ever will...this project is dead in the water now
Old Nov 10, 2013 | 06:11 PM
fishhook86's Avatar
Car: '86 Camaro
I'm no great mechanic in person, and probably not as good as that over this. You might get a better answer from someone else.
Old Nov 10, 2013 | 07:59 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
red fluid that doesn't smell burnt is a good sign-did you check fluid level yet?-if in doubt you can pour in more and see if tranny starts to operate normal.it is common for an older automatic tranny to lose fluid if they sit unused for a while. A faulty transmission often only needs a minor repair or adjustment-far from"dead in the water"just yet
Old Nov 10, 2013 | 08:29 PM
mikey8494's Avatar
Axle/Gears: stock
oh thank god
Old Nov 10, 2013 | 09:12 PM
mikey8494's Avatar
Axle/Gears: stock
is there anything i can do to fix it myself
Old Nov 11, 2013 | 05:35 AM
drdave88's Avatar
Engine: 6.0L
I would check your fluid level (level ground in neutral and warm). If its low, add a lil bit at a time until its at the full mark. Then shift through the gears slowly, and check it again. If you still have the problem, there are some adjustments that can be made. You will want to consult the trans board here or get a manual to read up on adjusting the bands in the trans, I'm not too familiar with them (T5 guy). Or you can find some shops that will do it for a decent price.
Old Nov 11, 2013 | 08:22 AM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
If the trans fluid is bright red and looks new, it may have been changed just prior to you getting it to try and cover up an issue. An old trick is to put fresh fluid in along with some brake fluid - it swells the seals and stops leaks and can make it shift better. For a little while, then it goes bad again.
Either way, definitely look into adjusting the bands and ensure you put new fresh fluid in.
Old Nov 11, 2013 | 09:28 AM
Lynn1990IRocZ's Avatar
Car: 1990 Iroc Z
You could have a restricted exhaust maybe? Ive seen it before where people think trans is slipping but it turns out that muffle or cat is just extremely plugged
Old Nov 11, 2013 | 11:09 AM
mikey8494's Avatar
Axle/Gears: stock
no the exaust is flowing very well
Old Nov 11, 2013 | 12:21 PM
Car: 1990 Iroc Z
Do a stall speed test by placing trans in drive and holding the brake and revving the engine until it reaches its maximum rpm and begins to stall, if its higher than roughly 2 grand, this indicates that you have slipping in your trans. Do this in every gear and if it appears high in all gears then most likely it is a pressure problem, if it is only in a certain gear than it is most likely a burnt holding member in that particular gear
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
