cruise control
Old Nov 10, 2013 | 09:48 AM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
cruise control
hi the car has been welded now but he took off the cruise control cable off its the that goes from the gear shifter part that goes in somewere in the driver side i don't know where it goes at all
Old Nov 10, 2013 | 10:26 AM
Joe Tag's Avatar
Re: cruise control
Gonna need a better description or pics, complete sentences help too. Is this cable on the interior? As in coming from the gear selector and over to driver side under the dash?
That would be the shifter lock, to keep the car from being shifted when the key is not on.
Old Nov 10, 2013 | 10:37 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
yes the cable is in the interior and it is coming from the gear selector to the drivers side on the floor then goes up behind the brake pedal other than that i don't know anymore as i didn't take it off
Old Nov 10, 2013 | 10:38 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: cruise control
Probably one goes to throttle body .... there another that goes to a vac plunger up in the front corner, usually driv side.
Is it one of these ?
Attached Thumbnails cruise control-trans-work-003.jpg   cruise control-tpi-005a.jpg
Old Nov 10, 2013 | 10:46 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
no i have moved cable in the first pic and it goes to the carb is that the cable going to a part near the rad and a vacum pipe into a shpere the accelerater cable itself is fine
Old Nov 10, 2013 | 10:47 AM
Joe Tag's Avatar
Re: cruise control
It mounts to the column with two screws if I remember correctly. I can't find any images that will help you here. Hopefully someone can chime in.
Old Nov 10, 2013 | 10:52 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
its on a spring with a white clip on it behind that there is a black clip like a wire connector but not if that helps
Old Nov 10, 2013 | 10:55 AM
Joe Tag's Avatar
Re: cruise control
The best I can do for now. The "white" mount on top of the column above the dimmer switch.
Old Nov 10, 2013 | 10:57 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
i'll take a pic of it now
Old Nov 10, 2013 | 11:24 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
here are the pics
the first on is from the gear shifter
the other the other end of the cable
hope that helps
Old Nov 10, 2013 | 11:43 AM
Joe Tag's Avatar
Re: cruise control
Shifter lock out. The piece in the picture houses it. You will have to drop the column and remove the dimmer and ignition switch it is mounted to. Mark the position of the screws you remove with a sharpie to make the adjustment easier in reassembly.
Old Nov 10, 2013 | 11:54 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
what does that mean do i have to take the dash out as well where is the dimmer and ignition switch then the cable should connect is the shifter lock anything to do with cruise control if so its never worked before
Old Nov 10, 2013 | 12:01 PM
Joe Tag's Avatar
Re: cruise control
Totally unrelated to the cruise. The dimmer is below the circled part, the ignition switch is above it in the pic. It mounts to the ignition switch, but the dimmer is mounted on top of it. You just need to remove the two 13mm nuts that secure the column mounting bracket to drop the column.
That is, assuming from your pics the hush panel and trim under the column is already removed.
Old Nov 10, 2013 | 12:12 PM
Joe Tag's Avatar
Re: cruise control
Going to use my powers of intuition to say your next threads will be "need shifter lockout housing" and "how to adjust dimmer and ignition switch"
Old Nov 10, 2013 | 12:15 PM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
yes it is , is that where it goes into whats the shifter lock out and what the dimmer
Old Nov 10, 2013 | 12:21 PM
Joe Tag's Avatar
Re: cruise control
It locks the shifter so it can not be moved without the ignition on as stated in my first post. The dimmer switches between high and low beams.
Old Nov 10, 2013 | 12:35 PM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: cruise control
thats strange with ignition off before it was taken off it never locked the shifter before at all
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
