ses light only in "d" gear really strange.
Old Nov 22, 2013 | 12:58 AM
chiyado's Avatar
Hello I have a 86 iroc z28 and I am having a issue. If I shift into overdrive and drive with the shifter slightly pushed twards nutral (still in overdrive) everything is fine and dandy. If its slightly pushed to drive (still in overdrive) it will pop a ses light after about 5min but when trying to read the code its gone. If it does turn on I can slightly push the shifter up and around 6 to 10 min the light turns off. But in drive gear itself the light turns on. But when I try to check it the code is gone. I had the transmission rebuilt not even 4000 miles on it 4 months ago. Just really strange and im 22 and know enough about parts but not the why it happens. The car runs great. Ive replaced starter waterpump accel coil whole tune up. New exhaust no cat and no smog all plugged proper and it drives really nice. Just issue in the shifter with slight bump ses light comes on but cant get code.
Sorry for grammar im typing on phone but I love this site and its awsome to do most reading.
Old Nov 22, 2013 | 07:31 PM
Damon's Avatar
Re: ses light only in "d" gear really strange.
Wow. That is weird. I got nothin' on this one. Some bizarre park/neutral switch problem, perhaps??
Old Nov 22, 2013 | 08:53 PM
chiyado's Avatar
That actually sounds like a good theory. The switch itself is actually bolted to the shift mechanism.
Old Nov 25, 2013 | 05:30 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Temporary Transanity
You are setting Temporary Code 36 when you are fiddling with the shifter.
Happy Racing!
They Want To Put HOW MANY Cameras In My Car Next Year ? ! ? ! ? !
Old Nov 26, 2013 | 11:46 PM
chiyado's Avatar
Re: Temporary Transanity
That would make since. Havent had a warm enough day to change out neutral safe sw yet. Too cold in wy. I just cant see why its soo sensitive.
Old Nov 30, 2013 | 12:55 AM
chiyado's Avatar
Was able to get the code to pop up then I quickly turned off the car and red the code seams to be code 24 when shifter is bumpted twards drive. That shows a possibility of vss.
Old Dec 2, 2013 | 04:57 PM
NINÅ's Avatar
Transmission: 765R4
True.
Code 24 is set whenever there are no pulses from the VSS and the shifter is in “drive”.
That’s normal.
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Dec 4, 2013 | 01:27 AM
chiyado's Avatar
Thankyou. I was worried.
eightsixseven
Dec 16, 2024 01:50 PM
red90IROCls1
Aug 25, 2015 06:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
