Riding on a prayer!!!
Old Nov 26, 2013 | 11:05 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
so i want to buy a car that has a warped head and bad valve seals but it runs and the owner assures me that it will make the trip from Fayetteville NC to Chattanooga TN roughly 7 hour drive about 450 miles. My question is should i drive it home or fork over 400 dollars to tow it
Old Nov 26, 2013 | 11:18 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Riding on a prayer!!!
Rent a u-haul trailer or tow dollie. Might be more economical.
Are you looking for a rebuild project, parts car, or just a car to.part out yourself?
I dont think anyone anywhere will make any sort of guarentee like that.
Warped heads means bad karma :-)
Old Nov 26, 2013 | 11:59 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
just a easy project car butuhaul wants 400 dollars since i have nothing to tow it with
Old Nov 27, 2013 | 12:25 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
A U-haul truck and U-haul car dolley shouldn't cost $400...
Old Nov 27, 2013 | 06:05 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Getting broke down in the middle of no where could cost more than any 400 bux.......
Old Nov 27, 2013 | 08:36 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
well can someone suggest a better or cheaper option
Old Nov 27, 2013 | 01:15 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Find someone with a truck and rent a trailer from uhaul. There aren't many options. I wouldn't drive it. In my younger days I would have took the chance. But I'm not as bold now. 450 miles is a long way to go.
Old Dec 3, 2013 | 08:55 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
So I got the car back home and it ran perfect theres only a few problems with the car but warped head i think not...but any way one of the problems is after the car is warmed up it wont want to start it acts like the car has a dying battery basicly the starter wont spin fast enough to start the engine any ideas
Old Dec 3, 2013 | 09:10 PM
Car: '87 Camaro
If you mean after you shut it off for a short time then try to start it but it will not, it could be either the starter is going out, heat soak, bad solenoid.
If it does it all the time, possible other issues.
Good to hear you were brave enough to drive it!!..
Do a battery // alternator // draw test.
If you dont want to drive it again, take the battery & alternator to autozone, oreileys, pepboys, etc for free testing. That will show or eliminate charging system.
Old Dec 3, 2013 | 09:15 PM
Car: '87 Camaro
DOH!!!
Check sparkplugs for coolant also!!!
Old Dec 3, 2013 | 09:25 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
non whatsoever the car looks flawless but the guy said he was guessing it had a warped head since when it go warm it doesnt want to start but if you let it cool down for like 20 min it starts fine like nothing was ever wrong its just like it cant spin the engine fast enough kinda reminds of a remote conroll car with a low battery
Old Dec 3, 2013 | 09:27 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
by the way i have been driving it like no tommorrow the thing is a beast the guy said it had a swapped 350 but that thing is fast all the way love it so far
Old Dec 3, 2013 | 09:41 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
sounds like a bad starter, or timing is off a little
if it were me, and no water in the oil ... i would grab a used starter and put it on to check it out
Old Dec 4, 2013 | 05:01 AM
Dakota W.'s Avatar
Anything is fast compared to a 3.1l...Take the starter to O'reilly's and have them test it, also make sure it's not getting vaporlocked.
Old Feb 8, 2014 | 01:39 AM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
The so called Blown Head gasket turned out to be a bad alternator and a pair of mismatched injectors lol
Old Feb 8, 2014 | 01:49 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I bet it runs like a totally different car now
blackz281le
Jan 11, 2016 07:51 AM
1992Z28!
Nov 19, 2015 07:33 AM
86White_T/A305
Sep 21, 2015 05:28 PM
Linson
Sep 21, 2015 01:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
