Estimated weight?
Old Dec 2, 2013 | 10:35 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
1984 z28 350 5 speed manual Hard top No a/c Two racing seats, no back seats No stock dash, controls, blower motor heater core NOTHING except for an aluminum dash. Fiberglass hood Manual windows No wiper motor or charcoal canister Just curious, car feels really light and sits up a bit higher than stock all the way around
Any other info you guys need?
Attached Thumbnails Estimated weight?-image-1651854898.jpg   Estimated weight?-image-2926222351.jpg
Old Dec 3, 2013 | 12:11 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Estimated weight?
Somewhere between 3200 and 3800lvs
that's my WAG
Old Dec 3, 2013 | 01:38 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
2850
Old Dec 3, 2013 | 01:41 PM
Car: 1971 Camaro
Engine: 427
^ that's light!
Old Dec 3, 2013 | 01:46 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
sounds like he has it stripped down pretty good-stock it was probably ~3200
Old Dec 3, 2013 | 01:59 PM
Car: 1971 Camaro
Engine: 427
Most I have seen actully weigh closer to 3500lbs
of course amount of fuel and with or without driver are 2 major variables.
Only way to know for sire is to hit the scales.
Old Dec 3, 2013 | 03:33 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by Johnny Blaze
Most I have seen actully weigh closer to 3500lbs of course amount of fuel and with or without driver are 2 major variables. Only way to know for sire is to hit the scales.
Hardtop 5 speed with hardly any options? 3500? Of course without me in it!
Old Dec 3, 2013 | 03:34 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by 8t2 z-chev
2850
That would be nice!
Old Dec 3, 2013 | 04:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
This summer I was trying to get a tenth off my ET to qualify for an ET-restricted class, so I pulled a bunch of stuff out. '82 Berlinetta, LS1/4L60E, 10-bolt, no AC (does have heat), passenger and rear seats removed, door panels removed, spare tire and jack removed, rear cargo cover removed, rear carpet removed, hood blanket removed, all junk in the console storage removed. Berlinetta rims (pretty light) with Hoosier 26x9.50-14 Quick Time Pro DOTs on the rear (really light), 185x70-14 highway radials on the front (fairly light). Just enough gas in the tank to keep the pump from cavitation. With me, it weighed 3200 lbs.
I had stock dash w/CD stereo, you don't. You have GFX, I don't. I have aluminum block and heads, you don't (assume you don't - you didn't mention that). I have thin-tube headers and no cat, not sure if you have cat. You have a fiberglass hood, I don't. I don't know about a T5, but I know a T56/flywheel/clutch weighs more than a 4L60E/flexplate/10" lock up torque converter.
I'd guess you're at least at 3200 lbs w/o driver.
Old Dec 3, 2013 | 04:49 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I have shorty edelbrock headers, no cat, 3 inch stainless exhaust. 3200 with you in it is pretty light! I heard the t-5 is at least 100lbs lighter than a 700r4 but the t-56 is about the same as an automatic, I'm really not sure..
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
ULTM8Z
Sep 16, 2015 09:15 AM
