What heads are these?
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I've searched google and all I can find is 86 350, doesn't even say truck next to it. 1.94 1.6 valves I think but I'm not sure what they came off of?
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: What heads are these?
seem to be out of any 1986 gm 350 car
3970010 Engine Blocks Small Block V8 1969 302, 4 bolt, Camaro Z28
3970010 Engine Blocks Small Block V8 1969-1980 350, 2 bolt or 4 bolt
guess you will gave to check the bore size to know for sure if it is a 4 bolt, if it is a 2 bolt, then you know
The block is the single most common 4" bore casting from about 69 to 80. Came in absolutely every imaginable 350 application from 160 HP Impala 2-bbl to Vettes to trucks to ... everything else. A few 327s and 302s as well. No need to "check" the bore; it's 4", plus whatever overbore.
Basically, random junk. Not worth worrying about what they are beyond that.
sofa was right about the bore, it would be the same in either 4", it was the short (3") stroke that gave it 302 cid
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Basically, random junk. Not worth worrying about what they are beyond that. The block is the single most common 4" bore casting from about 69 to 80. Came in absolutely every imaginable 350 application from 160 HP Impala 2-bbl to Vettes to trucks to ... everything else. A few 327s and 302s as well. No need to "check" the bore; it's 4", plus whatever overbore.
I don't understand...
Guy asks what heads they are. I tell him. What do you suppose I should have said instead?
So his heads are some kind of junk stock crap, and I'm willing to tell him THE TRUTH straight-up without any candy-coating; that makes me "king"? What are you anyway, some kind of an "alternate winner" all through school, and the idea that some things are not as good as some others, and some aren't any good AT ALL, bothers you somehow?
It's a 350, that's almost certain. Doesn't make the slightest bit of difference where the block came from, because as "almost" certain as it being a 350, it's equally "almost" certain it's been rebuilt. And once you take the guts out of a block, it becomes exactly equal to all other such blocks, in terms of "lucky" and all that; the sheet metal (or fiberglass) that GM originally wrapped it in, becomes altogether irrelevant. You can take the mightiest "LT-1" block and stick a 442 cast crank in it, some Badger or similar "rebuilder" pistons, a 929 cam, and a pair of (or ... just, 2) random junk heads on it, and voilà! instant 70s 160 HP smogger turd. Or, take a block from the lowliest 74 G10 van 350 2-bbl, and put 14:1 domes in it, a pair of 220cc aftermarket heads, a solid roller cam, and get 650 HP out of it. In NO case does the provenance of the block have any effect whatsoever on the finished product. Its condition, the quality control in its machine work, and such as that, might; but "Vette" or "van" or "Nova" or whatever, no.
Yes it's definitely better than having a 305. And of course, "running" and reliable transportation, is all good too. But also, definitely not as good as it could be. The first step in getting to that "goal" is, identifying what you've got. So what you've got is, a common 350 block (good as far as that goes), garbage heads (you know that they're NOT a foundation for a "competitive" engine) that are among the first things that need to go in the trash in your quest to improve your engine, no idea what pistons whoever rebuilt it put into it yet, no idea what cam is in it, and so forth. You know for sure though what at least SOME of your upgrade paths are.
So his heads are some kind of junk stock crap, and I'm willing to tell him THE TRUTH straight-up without any candy-coating; that makes me "king"? What are you anyway, some kind of an "alternate winner" all through school, and the idea that some things are not as good as some others, and some aren't any good AT ALL, bothers you somehow?It's a 350, that's almost certain. Doesn't make the slightest bit of difference where the block came from, because as "almost" certain as it being a 350, it's equally "almost" certain it's been rebuilt. And once you take the guts out of a block, it becomes exactly equal to all other such blocks, in terms of "lucky" and all that; the sheet metal (or fiberglass) that GM originally wrapped it in, becomes altogether irrelevant. You can take the mightiest "LT-1" block and stick a 442 cast crank in it, some Badger or similar "rebuilder" pistons, a 929 cam, and a pair of (or ... just, 2) random junk heads on it, and voilà! instant 70s 160 HP smogger turd. Or, take a block from the lowliest 74 G10 van 350 2-bbl, and put 14:1 domes in it, a pair of 220cc aftermarket heads, a solid roller cam, and get 650 HP out of it. In NO case does the provenance of the block have any effect whatsoever on the finished product. Its condition, the quality control in its machine work, and such as that, might; but "Vette" or "van" or "Nova" or whatever, no.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I don't understand... Guy asks what heads they are. I tell him. What do you suppose I should have said instead?
So his heads are some kind of junk stock crap, and I'm willing to tell him THE TRUTH straight-up without any candy-coating; that makes me "king"? What are you anyway, some kind of an "alternate winner" all through school, and the idea that some things are not as good as some others, and some aren't any good AT ALL, bothers you somehow? It's a 350, that's almost certain. Doesn't make the slightest bit of difference where the block came from, because as "almost" certain as it being a 350, it's equally "almost" certain it's been rebuilt. And once you take the guts out of a block, it becomes exactly equal to all other such blocks, in terms of "lucky" and all that; the sheet metal (or fiberglass) that GM originally wrapped it in, becomes altogether irrelevant. You can take the mightiest "LT-1" block and stick a 442 cast crank in it, some Badger or similar "rebuilder" pistons, a 929 cam, and a pair of (or ... just, 2) random junk heads on it, and voilà! instant 70s 160 HP smogger turd. Or, take a block from the lowliest 74 G10 van 350 2-bbl, and put 14:1 domes in it, a pair of 220cc aftermarket heads, a solid roller cam, and get 650 HP out of it. In NO case does the provenance of the block have any effect whatsoever on the finished product. Its condition, the quality control in its machine work, and such as that, might; but "Vette" or "van" or "Nova" or whatever, no. Yes it's definitely better than having a 305. And of course, "running" and reliable transportation, is all good too. But also, definitely not as good as it could be. The first step in getting to that "goal" is, identifying what you've got. So what you've got is, a common 350 block (good as far as that goes), garbage heads (you know that they're NOT a foundation for a "competitive" engine) that are among the first things that need to go in the trash in your quest to improve your engine, no idea what pistons whoever rebuilt it put into it yet, no idea what cam is in it, and so forth. You know for sure though what at least SOME of your upgrade paths are.
So his heads are some kind of junk stock crap, and I'm willing to tell him THE TRUTH straight-up without any candy-coating; that makes me "king"? What are you anyway, some kind of an "alternate winner" all through school, and the idea that some things are not as good as some others, and some aren't any good AT ALL, bothers you somehow? It's a 350, that's almost certain. Doesn't make the slightest bit of difference where the block came from, because as "almost" certain as it being a 350, it's equally "almost" certain it's been rebuilt. And once you take the guts out of a block, it becomes exactly equal to all other such blocks, in terms of "lucky" and all that; the sheet metal (or fiberglass) that GM originally wrapped it in, becomes altogether irrelevant. You can take the mightiest "LT-1" block and stick a 442 cast crank in it, some Badger or similar "rebuilder" pistons, a 929 cam, and a pair of (or ... just, 2) random junk heads on it, and voilà! instant 70s 160 HP smogger turd. Or, take a block from the lowliest 74 G10 van 350 2-bbl, and put 14:1 domes in it, a pair of 220cc aftermarket heads, a solid roller cam, and get 650 HP out of it. In NO case does the provenance of the block have any effect whatsoever on the finished product. Its condition, the quality control in its machine work, and such as that, might; but "Vette" or "van" or "Nova" or whatever, no. Yes it's definitely better than having a 305. And of course, "running" and reliable transportation, is all good too. But also, definitely not as good as it could be. The first step in getting to that "goal" is, identifying what you've got. So what you've got is, a common 350 block (good as far as that goes), garbage heads (you know that they're NOT a foundation for a "competitive" engine) that are among the first things that need to go in the trash in your quest to improve your engine, no idea what pistons whoever rebuilt it put into it yet, no idea what cam is in it, and so forth. You know for sure though what at least SOME of your upgrade paths are.Senior Member
So his heads are some kind of junk stock crap, and I'm willing to tell him THE TRUTH straight-up without any candy-coating; that makes me "king"? What are you anyway, some kind of an "alternate winner" all through school, and the idea that some things are not as good as some others, and some aren't any good AT ALL, bothers you somehow?Supreme Member
Car: 87 iroc-z
Engine: 454
Transmission: th350
14034808 350 80-86 1.84/1.50 76cc
14034810 350 80-86
14034811 350 80-86
14039121 305 81-86
14039122 305 81-86
14071114 350 80-86
14075381 350 80-86
14079261 350 82-85
14085844 350 80-86
14089119 350 80-86
http://www.chevymania.com/
unfortunetly,......well,....i wont use the "J" word.
And Barlow, the fact that it's not your post and you just have to get your panties all in a wad and come in here trying to bust on somebody that's none of your business, just demonstrates that whole "alternate winner" mentality that goes in general with the Internet's liberal manufactured outrage machine.
I frankly don't give a rip what you think; I'm gonna tell THE TRUTH even if it hurts whiners like you.
Mr B, glad I could help.
I'm sorry this other .... individual ... had to come in here and pollute your thread. I'll apologize FOR him, since he doesn't seem like the type that will man up and realize the error of his ways and apologize for himself. Those "alternate winner" types never do, it's always "somebody else's" fault anyway whenever they screw up and make a fool out of themselves. (mine in this case I'm sure)
Meanwhile, the heads look like ... C'mon Barlow, tell us HONESTLY, what do they look like to YOU?
I'm sorry this other .... individual ... had to come in here and pollute your thread. I'll apologize FOR him, since he doesn't seem like the type that will man up and realize the error of his ways and apologize for himself. Those "alternate winner" types never do, it's always "somebody else's" fault anyway whenever they screw up and make a fool out of themselves. (mine in this case I'm sure)Meanwhile, the heads look like ... C'mon Barlow, tell us HONESTLY, what do they look like to YOU?
Now...
Mr B, right, you can do all the external sort of things; exhaust, drive train, paint job & interior, etc.; and just let the motor be, if it's reliable and gets you around. No need to just jump in and start spending money on something that's working, regardless of the excellence (or lack thereof) of the castings.
Best way these days to come up with the best possible core, is to watch the boneyards for a 96-2000 truck motor, and do your buildup on that. Even if you don't want those specific heads (Vortec), you can always sell em. Meanwhile, that's a good way to get a roller block, with all the roller stuff still in it, and it'll have MODERN quality control instead of the death-of-the-US-auto-industry sloppiness of the 70s. I'd do that, a LONG time before I'd buy a whole "crate" motor, myself.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Now... Mr B, right, you can do all the external sort of things; exhaust, drive train, paint job & interior, etc.; and just let the motor be, if it's reliable and gets you around. No need to just jump in and start spending money on something that's working, regardless of the excellence (or lack thereof) of the castings. Best way these days to come up with the best possible core, is to watch the boneyards for a 96-2000 truck motor, and do your buildup on that. Even if you don't want those specific heads (Vortec), you can always sell em. Meanwhile, that's a good way to get a roller block, with all the roller stuff still in it, and it'll have MODERN quality control instead of the death-of-the-US-auto-industry sloppiness of the 70s. I'd do that, a LONG time before I'd buy a whole "crate" motor, myself.
First off, I'm going to start with the tires, suspension and rear.
I would like to take the car to a dyno to see where I'm at now to figure out a power goal of where I want to be.
I know all about the vortec motors! I had a 98 silverado and I had two sets of vortec heads last year! All that went to the junkyard :/ but I'll be on the lookout when I actually go to source a block to build.
Way to contribute helpfully to the OP's thirst for knowledge.
I'm still sorry ON YOUR BEHALF since you're still not willing to apologize in person after acting a jerk, and will continue to apologize FOR YOU, until such time as you become a man with a spine and realize that it's the right thing to do. Oh well. You can go right on ahead with your "righteous indignation" on somebody else's behalf pretending to be "offended" even though YOU'RE NOT, and be as much of the "alternate winner" that you are displaying yourself to be, as much as you like. Until you apologize both TO ME and TO THE PERSON WHOSE POST YOU FORNICATED, I really don't have anything more to offer you and therefore will just ignore you, but I'll be happy to help out the gentleman who wants to know what his engine parts are.
Well Mr B, that sounds like a pretty decent plan; work on things that need it, leave alone what's working well enough, until its time arrives.
Good luck wit it!!
Good luck wit it!!
Car: 87 iroc-z
Engine: 454
Transmission: th350
one fact is they're small valve, open chamber/low compression heads. they were made on june, 2, 1985. nothing fancy about them. run em til it blows up or you get something better, or sell them, but i would'nt put any money into them.
wether or not somebody is a "dick" for calling them "junk", is outside the scope of my knowledge level at this point and time of reality, reconsiderations of the original question that was at hand by the original poster can only be answered by the one that asked the question, then received a possible answer that was straightforward and to the point, yet challenged about its integrity and usefulness to the here & now & future possibilities of being useful or of the possible rafifications of being such "junk", or blunt truthfulness to in all actuality be helpful in a non-evasive nature.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
one fact is they're small valve, open chamber/low compression heads. they were made on june, 2, 1985. nothing fancy about them. run em til it blows up or you get something better, or sell them, but i would'nt put any money into them. wether or not somebody is a "dick" for calling them "junk", is outside the scope of my knowledge level at this point and time of reality, reconsiderations of the original question that was at hand by the original poster can only be answered by the one that asked the question, then received a possible answer that was straightforward and to the point, yet challenged about its integrity and usefulness to the here & now & future possibilities of being useful or of the possible rafifications of being such "junk", or blunt truthfulness to in all actuality be helpful in a non-evasive nature.
how did you find that info out?
They were cast (or, the one was, at least) on the 02 day of the Jth (10th, October) month of a year ending in 5.
June would have started out w F.
Car: 87 iroc-z
Engine: 454
Transmission: th350
from the casting date in your picture, "j025" i actually made a mistake, it wasnt june.
J=october
02= day of month
5= year, 85
got info here;
http://www.crankshaftcoalition.com/w...n#Casting_date
J=october
02= day of month
5= year, 85
got info here;
Yup, no biggie...
With a few of those, the year can be a bit ambiguous. For example, we know that the particular head casting, was only available in the early-mid 80s; so 85 is beyond doubt. However, if your block happened to have a code ending in 9 or 0, then it could have been cast in either 69 or 79, or 70 or 80. In that case the stamping code could be used to resolve the uncertainty. Not that it really matters too much though, beyond historical curiosity; we're not doing a "matching numbers" build here, like the guys that try to find the right block cast in the right date range for their car's mfr date, and the right heads also made in the right time frame.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
