Vortec head project
Old Jan 30, 2014 | 07:03 AM
acerulz's Avatar
Car: 1984 Cadillac Brougham
Engine: 1989 Iroc Z 350
Vortec head project
ok, I know this thread will be like beating a dead horse for some but I wanna put 98 350 vortec heads onto my 350 tbi. I've been searching a lot of threads but haven't found what I'm looking for. I am looking for kind of a step by step process of what has to be done to make this work. It's a 350 solid lifter motor from '89 that I built 2 years ago, I have a complete vortec engine on the shop floor with low miles, and want to do this on the cheap so I want to use as much as possible from the donor motor. Also, I remember seeing posts before about being able to drill and tap the heads to accommodate the original tbi intake but can't remember exactly what had to be done. anyone have any links that can help me out? also would like to convert to roller cam, can I just swap out all the parts from the donor motor and bolt them into my block? thanks in advance.
Old Jan 30, 2014 | 02:59 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Re: Vortec head project
Just use the vortec heads and do not use a tbi intake they are very restrictive buy a vortec carb intake like a rpm airgap and use a tbi adapter plate on it like the one transdapt makes.
Old Jan 30, 2014 | 04:30 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
The bolt holes aren't the only problem with using a regular pattern manifold on vortec style heads.
read
http://www.gmhightechperformance.com.../photo_07.html
Old Jan 30, 2014 | 05:13 PM
So ... you're thinking all you have to do is drill some holes?
Whaddya think NOW? (note the holes already neatly drilled)
Best plan is, get a good 4-bbl intake. If you wanna use TBI on it, just get a TBI adapter as well. Just make sure it's not one of the ones that moves the TB from its factory spot; I think the one to avoid is the Holley one but I could be wrong; it makes it about impossible to get all your cables and lines and whatnot to work.
Old Jan 31, 2014 | 07:19 AM
acerulz's Avatar
hmmmm, well then lol. really wanna do this project, but looks like I'll havta pony up some extra change and get the proper intake lol. am I able to convert my 350 to a roller rocker setup or is that going to have some hidden surprises for me as well?
Old Jan 31, 2014 | 08:10 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Converting a non roller to a roller is a fairly expensive project.
Old Jan 31, 2014 | 07:25 PM
Your 89 block should readily accommodate the factory roller cam stuff. All you need is to find a blown-up motor with that in it. A 96 - 2000 truck would be the perfect target to look for.
Roller rockers, you just go to the store and buy, same as everybody else. Either they're worth the $$$ or not, to YOU. You gotta be th ejudge of that.
Old Jan 31, 2014 | 08:33 PM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
-Use the vortec motor on the floor
-strip it apart till its a long block
-buy an edelbrock manifold or other brand http://www.jegs.com/i/GM+Performance...FeJF7AodMjkACw
-reconnect all wires and hoses
-Get a custom chip
Done!
I would recommend doing other performance upgrades while you have it apart but this is the basics.
Old Jan 31, 2014 | 09:57 PM
acerulz's Avatar
would love to use the vortec motor I got, but it would be a damn shame cuz I just built the 350 2 years ago lol. time to do some major pondering on this one lol.......
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
