350 valves and springs?
Old Feb 13, 2014 | 11:22 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Im rebuilding an 82 c30 350 block and im wantijg to install new valve springs and valves. Im not sure what snd where to buy. The valves I believe are 1.94 and 1.60s? Theyre in a set of 487 heads. Help or suggestions please. On my l31 I reused the valves and lapped them and used alex springs but never rebuilt a motor from stratch before.
Old Feb 14, 2014 | 05:09 AM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Re: 350 valves and springs?
IIRC,the 487 heads came w/ either 2.02/1.60 or 1.94/1.50 valves,so,you mite wanna measure to see what you have.Heads made after 74 are thinner & prone to cracking,so,having them magged befor dumping any money in them would be smart.As for springs,use whatever brand you prefer w/ the proper specs for the cam being used.
Old Feb 15, 2014 | 08:59 AM
Engine: L31 350
Ilk measure them next time im in the garage. Where's the best place to get valves though?
Old Feb 15, 2014 | 09:27 AM
jokerZ71's Avatar
Engine: 5.7 Vortec
Axle/Gears: 3:42
Summit,Jeg's, any of the big parts houses will have a wide assortment of valves.You just need to be sure of what you actually have before ordering.To be honest,by the time you buy valves,springs,& rework those,you'll be close to the price of a better set.Lots of times,you can keep a ck @ local machine shops & pick up a set good rebuilt heads that someone didn't pay for.
Cameeeero
Sep 18, 2015 04:00 PM
crazynights
Aug 21, 2015 06:53 AM
Out-Cast
Aug 17, 2015 10:57 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
