need help! Better response with my setup
Old Feb 19, 2014 | 11:30 AM
89camaroz's Avatar
Hey guys so I have a few things I really do need help with.
1.) when driving around it sounds and feels like my car stutters for half a second and happens quite a bit.(fuel? Vacuum?)
2.) I will be driving for maybe 20 minutes and try to punch it. It will stutter pretty bad and almost die. Again (fuel problem?)
I have a edelbrock carb, intake, with a chevy 350 crate engine.
If u need any other info let me know! Will post pics
Old Feb 19, 2014 | 12:00 PM
89camaroz's Avatar
Re: need help! Better response with my setup
It almost sounds an feels like a misfire. Could it be the wires, plugs, coil or distributor?
Old Feb 19, 2014 | 12:22 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
It could be all of those things. Those wires look new though, so that's probably not it if they are. If it's intermittent but not specific to one or a couple of cylinders, I would check the gap on the spark plugs or the coil. If you can isolate it to one or a group of cylinders (even intermittently) I would replace the cap/rotor. If you have a timing light, you can hook it up to each wire and check for the light pulses while revving. I had an issue where I had a random misfire that was significant enough to notice while driving. I used the timing light to isolate it to cylinders 3 and 5, which told me it was probably the cap and rotor and so I replaced them.
On a side note: if you have the funds, just replace the cap and rotor if they're old ~$35 at Autozone. The coil is cheap too ~$27 from Autozone.
Old Feb 19, 2014 | 12:36 PM
89camaroz's Avatar
Hey man thanks for the reply! I will replace cap and rotor this weekend! I gap the plugs around .45. I've heard .35-.40 is perfect. And I'm not sure if I have a timing light or not. It's just bothersome cuz I'm losing power somewhere and I think it's that misfire/ whatever it is. I should be pushing a good amount of torque and power but I'm not getting what I want. I will get new spark plugs/ rotor/ cap.
Old Feb 19, 2014 | 12:44 PM
Engine: 5.7 TPI
This is all assuming it's not fuel related. If you're pushing too much fuel and driving the AFR too far down this could happen. I'm assuming too MUCH fuel, since it sounds like it's worse under heavy throttle. If the cap and rotor doesn't do it for you, check the jets for your primaries. Also, have you tuned it at idle?
Old Feb 19, 2014 | 01:01 PM
89camaroz's Avatar
No tune at all. Except playing around with the idle screws a bit. How would I check the jets? Aren't they inexpensive also?
Side note: would seafoam possibly do anything?
If anything I am gonna get a new distributer all together, new wires with more ohms, and high performance plugs.
Old Feb 19, 2014 | 01:16 PM
89camaroz's Avatar
Also I think I might have too big of a carb! I have a 700cfm pretty sure. And I put it into that calculator and I should be around 600-650cfm! How big of a difference would that make with fuel and everything?
Old Feb 19, 2014 | 01:30 PM
Engine: 5.7 TPI
Jets aren't expensive. I think you can get a whole kit of them for around ~70, large and small. It's a little troublesome to take the carb apart, but not hard. There are plenty of good videos on youtube to walk you through it. Your carb is a little big, but I think you can re-jet it and tune it to get it to run better. If you have a vacuum gauge, you can tune the IMS for the idling AFR.
No to the seafoam, and I wouldn't replace that distributor unless you think it's bad. I don't know how much of the old ECM and electronics you're using, so it's tough to say what you should mess with regarding the distributor, but leave that alone for now and go for the carb. That should take care of your problem seeing as it is a little large.
Old Feb 19, 2014 | 01:52 PM
89camaroz's Avatar
Ok so ima start on the carb today. Once I get my tax return I'm more than likely gonna buy a 600 cfm carb. Or do you think 650? I'll probably buy the re-jet kit also just to have a back up carb that can run. As far as the ECM half of it is useless. Thanks for the help I will be on here a lot asking questions.
Old Feb 19, 2014 | 03:07 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I run an edelbrock 600 cfm on my 350. More than enough, really good throttle response.
Old Feb 19, 2014 | 03:22 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Without knowing for sure what your combo is I would probably say a 600.
Personally I like to get used ones cheap and rebuild them
Old Feb 19, 2014 | 04:01 PM
89camaroz's Avatar
Perfect 600 it is! Getting that with my tax return!
Old Feb 19, 2014 | 04:03 PM
89camaroz's Avatar
Thanks for the eeaponse! I'm gonna go with that 600 cfm! The response with mine sucks.
Old Feb 19, 2014 | 04:04 PM
89camaroz's Avatar
What exact info do you need? Like combo and auch? I can give u what I can just let me know
Old Feb 19, 2014 | 04:50 PM
midias's Avatar
What heads, cam, compression, etc
Generally a 600cfm carb can support 350s up to 400hp
If you get a 600 edelbrock you will probably want the 1405 you NOT the 1406 they are jetted differently
Old Feb 19, 2014 | 05:05 PM
89camaroz's Avatar
I have an electric choke. From what I've seen 1405 has manual choke.
Old Feb 19, 2014 | 05:08 PM
89camaroz's Avatar
I have an electric choke. From what I saw 1405 only has manual choke.? Also how do I know if I have an egr or not
Old Feb 19, 2014 | 05:38 PM
midias's Avatar
The 1405 comes with a manual choke but can have an electric choke bolted on.
Old Feb 19, 2014 | 06:56 PM
89camaroz's Avatar
How would I know what cfm my carb is right now? I didn't buy it
Old Feb 19, 2014 | 07:03 PM
89camaroz's Avatar
Just figured out I have a 1406! So for sure go with the 1405?
Mark_ZZ3
May 24, 2018 01:02 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
