Shutting off and no start
Old Mar 5, 2014 | 06:32 PM
Tigerfan13's Avatar
Car: 86 Iroc Z
Got a 86 iroc, after car gets warm it does not want to start back. Now it is also shutting off after running and not starting back. Thought it may be ignition module, replaced it and still doing the same thing. I have also swapped computers and that did not help. Any help would be appreciated.
Old Mar 5, 2014 | 07:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Shutting off and no start
When it won't start confirm strong spark at the plug
Pull some plugs out.
Wet plug ; generally no spark
Dry plug ; no fuel
Not uncommon for old injectors will fail when they heat up , do the injector resistance test ( when cold and when hot )
Old Mar 5, 2014 | 07:58 PM
Tigerfan13's Avatar
Car: 86 Iroc Z
I'll give it a shot, I'll let u know how it goes. Thanks
Old Mar 9, 2014 | 02:15 PM
Tigerfan13's Avatar
Car: 86 Iroc Z
Turned out to be tps sensor, somehow it got bumped and was off
Old Mar 9, 2014 | 05:06 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
1st thing to do when you have problems
https://www.thirdgen.org/forums/tech...s-dumbies.html
Old Mar 9, 2014 | 08:28 PM
Tigerfan13's Avatar
Car: 86 Iroc Z
That wasn't the only problem, got a bad wire somewhere behind distributor and a mess with the grounds, is there a diagram or something that shows the ground locations
Old Mar 9, 2014 | 10:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/tpi/...locations.html
Orr89RocZ
Apr 25, 2016 08:28 AM
chazman
Aug 22, 2015 02:01 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Fronzizzle
Aug 9, 2015 01:15 PM
