Modify Powermaster Alternator?
Old Apr 21, 2014 | 10:10 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am in the middle of installing my new alternator and that post where the battery cable mounts to, hits my valve cover. I can't really re-clock the alternator because my procharger support brace won't be able to be hooked up to it. So my question is can I dissemble the alternator somehow so that I can maybe just install a short stud or something instead of having the block there for the cable to bolt to?
Old Apr 22, 2014 | 06:20 AM
Re: Modify Powermaster Alternator?
Better plan would probably be, just dimple the VC.
Old Apr 22, 2014 | 06:22 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had the same issue. I had to modify the valve cover.
Old Apr 22, 2014 | 07:26 PM
Damon's Avatar
Cut the extra threads off just outbord of the nut. Don't use any washers and use a cheap parts-store replacement nut like they sell 50 to a bag (i.e. thin). It'll clear.
I've done this on every single serpentine 3rd gen I've owned that got a set of non-stock valve covers put on it!
Old Apr 22, 2014 | 08:51 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
There aren't any threads past the nut. Its a threaded hole that takes a bolt though it. The block itself that the wire bolts to is too big and hits the valve cover.
Old Apr 23, 2014 | 02:17 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
You might want to call Powermaster. I had that issue once and I was able to send them the alternator and they moved the stud for the power connection to the case of the alternator for better clearance. It didn't cost much and I had it back within a week or two.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
