coolant temp sensor / fan switch sensor
Car: 1985 trans am
So my question is, are both these sensors the same as in what they do? Here is my problem... the coolant temp sensor and the small clip that slides over the top of the sensor, clears the headers nicely. Now for the fan switch, which is in the same place but on the other side of the motor had a top that requires a big plastic plug that snaps on top, This makes for a very tight fit with the headers and I am worried about melting it down. Here are some pics to clarify what I am talking about. I was wondering if I could use the coolant sensor and change the plug as such to keep it away from the header??? thoughts??
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: coolant temp sensor / fan switch sensor
FWIW, the installation kit that came with my SLP tri-y headers included a 90-degree elbow for the fan switch. It points the sensor down towards the starter.
Car: 1990 Trans Am
Axle/Gears: Stock
The coolant gauge sensor is a sensor and delivers values within a certain range for the gauge to react to.
The other one is a pressure switch, not a sensor, and simply closes without sending values of any kind.
Therefore, you can not interchange them.
The stock big plastic plug tends to break down over the years anyway, due to its proximity to the header. At least mine did. The heat gets to them.
Car: 1985 trans am
Oh that is a good idea!! I will look into that and see if I can get one. The end of this connector is so close! thanks so much for the info!
Car: 1985 trans am
Car: 89 IrocZ
Engine: L98-ish
You should be able to get one at a hardware store...last I looked, SLP doesn't list much for 3rd gens anymore.
Car: 1985 trans am
Car: '87 IROC
Engine: LB9
Even with the elbow, get some fiberglass heat sleeve and put it around the connector. It still gets hot around there. Route the connector between the battery cable and the block.
Most "real" auto parts stores will have a replacement connector hanging on the wall if you need one.
This one was hurt but still in action when I replaced it.
SLP still owes me the spark plug socket. I bought the headers in April 1989.
Car: 1985 trans am
Sorry. No part number is listed. It's just a hardware store item. IIRC, it's a 1/4-NPT male/female elbow.
heat sock is a good call!!! ill deff do that as it is in like new condition at the moment.
eightsixseven
Dec 16, 2024 01:50 PM
TA8487
Aug 16, 2015 12:21 PM
