Camaro Stalls While Burning Out
Old Jul 21, 2014 | 02:06 PM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
I have a 91 Camaro RS 5 speed with a built 350 TBI in it. The car idles and drives great. I have one problem... I dump the clutch anywhere above 2500 rpm the car sputters, then backfires, and sometimes dies. Is it not getting enough fuel? Is the computer? Any help would be greatly appreciated!
Old Jul 21, 2014 | 03:46 PM
FBOMB90's Avatar
Car: 90 Pontiac Trans Am
Engine: 5.0 Liter
Re: Camaro Stalls While Burning Out
There is not really enough info provided to acurately diagnose the issue, but I'll give you a little food for thought. An engine only needs three things to run; fuel, air and spark. IMO the backfiring would lead me to lack of fuel.
Old Jul 21, 2014 | 09:13 PM
Car: 1991 Camaro RS
The car has a 454 throttle body.. It should be getting plenty of fuel..
Old Jul 22, 2014 | 05:26 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Just because you have a big TB on it does not mean the fuel is getting delivered. How does it act if you're rolling and hammer the throttle or launch from a lower RPM? Is there a delay in throttle response? Do you get any slight popping, pinging, anything like that? Have you checked for codes?
Old Jul 22, 2014 | 05:48 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Have you checked the TPS? https://www.thirdgen.org/tpimod2
Old Jul 22, 2014 | 07:22 AM
FBOMB90's Avatar
Engine: 5.0 Liter
Thank you
Old Jul 22, 2014 | 10:55 AM
Car: 1991 Camaro RS
Thank you
Yes, there is a slight delay in throttle response. Especially if you do launch from a low rpm. Sorry for leaving out details. And no I didn't check codes yet.
Old Jul 23, 2014 | 07:57 AM
FBOMB90's Avatar
Engine: 5.0 Liter
I would get a fuel pressure gauge on it. It sounds like you might have a clogged fuel filter or possible the sock at the bottom of the fuel pump.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
TreDeClaw
Aug 14, 2015 06:58 PM
92camaroJoe
Aug 13, 2015 06:07 AM
